[petsc-users] Makefile change for PETSc3.12.0???
Matthew Knepley
knepley at gmail.com
Wed Oct 2 12:58:28 CDT 2019
On Wed, Oct 2, 2019 at 1:54 PM Danyang Su via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear All,
> I installed PETSc3.12.0 version and got problem in compiling my code
> (Fortran and C++). The code and makefile are the same as I used for
> previous PETSc version.
> The error information seems the make command does not know the compiler
> information. I tested this on two linux workstations and both return the
> same error.
> make: *** No rule to make target '../../usg/math_common.o', needed by
> 'exe'. Stop.
> The makefile I use is shown below:
> #PETSc variables for development version, version V3.6.0 and later
> include ${PETSC_DIR}/lib/petsc/conf/variables
> include ${PETSC_DIR}/lib/petsc/conf/rules
> CFLAGS =
> CXXFLAGS = -std=c++11 -O3
> CPPFLAGS = -DUSECGAL_NO
> FFLAGS = -frounding-math -O3
> FPPFLAGS = -DLINUX -DRELEASE -DRELEASE_X64 -DPETSC -DPETSC_HAVE_MUMPS
> -DPETSC_HAVE_SUPERLU
> CLEANFILES = executable-linux
> SRC =./../../
> OBJS = $(SRC)usg/math_common.o\
> $(SRC)usg/geometry_definition.o\
> $(SRC)updtrootdensity.o
> exe: $(OBJS) chkopts
> -${FLINKER} $(FFLAGS) $(FPPFLAGS) $(CPPFLAGS) -o executable-linux
> $(OBJS) ${PETSC_LIB}
> Any idea on this?
Satish fixed this:
https://gitlab.com/petsc/petsc/commit/2f9dabc9ab2f7bb653429b8d7acc8cc6e2538062
It will be in the next patch release, but you can also just use the current
master branch.
Matt
> Thanks,
> Danyang
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191002/e9b27846/attachment.html>
