[petsc-users] Makefile change for PETSc3.12.0???
Danyang Su danyang.su at gmail.com
Wed Oct 2 12:53:33 CDT 2019
Dear All,
I installed PETSc3.12.0 version and got problem in compiling my code
(Fortran and C++). The code and makefile are the same as I used for
previous PETSc version.
The error information seems the make command does not know the compiler
information. I tested this on two linux workstations and both return the
same error.
make: *** No rule to make target '../../usg/math_common.o', needed by
'exe'.  Stop.
The makefile I use is shown below:
#PETSc variables for development version, version V3.6.0 and later
include ${PETSC_DIR}/lib/petsc/conf/variables
include ${PETSC_DIR}/lib/petsc/conf/rules
CFLAGS =
CXXFLAGS = -std=c++11 -O3
CPPFLAGS = -DUSECGAL_NO
FFLAGS = -frounding-math -O3
FPPFLAGS = -DLINUX -DRELEASE -DRELEASE_X64 -DPETSC -DPETSC_HAVE_MUMPS
-DPETSC_HAVE_SUPERLU
CLEANFILES = executable-linux
SRC =./../../
OBJS = $(SRC)usg/math_common.o\
     $(SRC)usg/geometry_definition.o\
     $(SRC)updtrootdensity.o
exe: $(OBJS) chkopts
     -${FLINKER} $(FFLAGS) $(FPPFLAGS) $(CPPFLAGS) -o executable-linux
$(OBJS) ${PETSC_LIB}
Any idea on this?
Danyang
