[petsc-users] Domain decomposition using DMPLEX
Matthew Knepley
knepley at gmail.com
Tue Nov 26 12:34:54 CST 2019
On Tue, Nov 26, 2019 at 12:24 PM Danyang Su <danyang.su at gmail.com> wrote:
> On 2019-11-26 10:18 a.m., Matthew Knepley wrote:
> On Tue, Nov 26, 2019 at 11:43 AM Danyang Su <danyang.su at gmail.com> wrote:
>> On 2019-11-25 7:54 p.m., Matthew Knepley wrote:
>> On Mon, Nov 25, 2019 at 6:25 PM Swarnava Ghosh <swarnava89 at gmail.com>
>> wrote:
>>> Dear PETSc users and developers,
>>> I am working with dmplex to distribute a 3D unstructured mesh made of
>>> tetrahedrons in a cuboidal domain. I had a few queries:
>>> 1) Is there any way of ensuring load balancing based on the number of
>>> vertices per MPI process.
>> You can now call DMPlexRebalanceSharedPoints() to try and get better
>> balance of vertices.
>> Hi Matt,
>> I just want to follow up if this new function can help to solve the
>> "Strange Partition in PETSc 3.11" problem I mentioned before. Would you
>> please let me know when shall I call this function? Right before
>> DMPlexDistribute?
> This is not the problem. I believe the problem is that you are
> partitioning hybrid cells, and the way we handle
> them internally changed, which I think screwed up the dual mesh for
> partitioning in your example. I have been
> sick, so I have not gotten to your example yet, but I will.
> Hope you are getting well soon. The mesh is not hybrid, only prism cells
> layer by layer.
Prism cells are called "hybrid" right now, which is indeed a bad term and I
will change.
Matt
> But the height of the prism varies significantly.
> Thanks,
> Danyang
> Sorry about that,
> Matt
>> call DMPlexCreateFromCellList
>> call DMPlexGetPartitioner
>> call PetscPartitionerSetFromOptions
>> call DMPlexDistribute
>> Thanks,
>> Danyang
>>> 2) As the global domain is cuboidal, is the resulting domain
>>> decomposition also cuboidal on every MPI process? If not, is there a way to
>>> ensure this? For example in DMDA, the default domain decomposition for a
>>> cuboidal domain is cuboidal.
>> It sounds like you do not want something that is actually unstructured.
>> Rather, it seems like you want to
>> take a DMDA type thing and split it into tets. You can get a cuboidal
>> decomposition of a hex mesh easily.
>> Call DMPlexCreateBoxMesh() with one cell for every process, distribute,
>> and then uniformly refine. This
>> will not quite work for tets since the mesh partitioner will tend to
>> violate that constraint. You could:
>> a) Prescribe the distribution yourself using the Shell partitioner type
>> or
>> b) Write a refiner that turns hexes into tets
>> We already have a refiner that turns tets into hexes, but we never wrote
>> the other direction because it was not clear
>> that it was useful.
>> Thanks,
>> Matt
>>> Sincerely,
>>> SG
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191126/6723cf94/attachment-0001.html>
