[petsc-users] Domain decomposition using DMPLEX
Danyang Su
danyang.su at gmail.com
Tue Nov 26 12:24:22 CST 2019
On 2019-11-26 10:18 a.m., Matthew Knepley wrote:
> On Tue, Nov 26, 2019 at 11:43 AM Danyang Su <danyang.su at gmail.com
> <mailto:danyang.su at gmail.com>> wrote:
> On 2019-11-25 7:54 p.m., Matthew Knepley wrote:
>> On Mon, Nov 25, 2019 at 6:25 PM Swarnava Ghosh
>> <swarnava89 at gmail.com <mailto:swarnava89 at gmail.com>> wrote:
>> Dear PETSc users and developers,
>> I am working with dmplex to distribute a 3D unstructured mesh
>> made of tetrahedrons in a cuboidal domain. I had a few queries:
>> 1) Is there any way of ensuring load balancing based on the
>> number of vertices per MPI process.
>> You can now call DMPlexRebalanceSharedPoints() to try and get
>> better balance of vertices.
> Hi Matt,
> I just want to follow up if this new function can help to solve
> the "Strange Partition in PETSc 3.11" problem I mentioned before.
> Would you please let me know when shall I call this function?
> Right before DMPlexDistribute?
> This is not the problem. I believe the problem is that you are
> partitioning hybrid cells, and the way we handle
> them internally changed, which I think screwed up the dual mesh for
> partitioning in your example. I have been
> sick, so I have not gotten to your example yet, but I will.
Hope you are getting well soon. The mesh is not hybrid, only prism cells
layer by layer. But the height of the prism varies significantly.
Danyang
> Sorry about that,
> Matt
> call DMPlexCreateFromCellList
> call DMPlexGetPartitioner
> call PetscPartitionerSetFromOptions
> call DMPlexDistribute
> Thanks,
> Danyang
>> 2) As the global domain is cuboidal, is the resulting domain
>> decomposition also cuboidal on every MPI process? If not, is
>> there a way to ensure this? For example in DMDA, the default
>> domain decomposition for a cuboidal domain is cuboidal.
>> It sounds like you do not want something that is actually
>> unstructured. Rather, it seems like you want to
>> take a DMDA type thing and split it into tets. You can get a
>> cuboidal decomposition of a hex mesh easily.
>> Call DMPlexCreateBoxMesh() with one cell for every process,
>> distribute, and then uniformly refine. This
>> will not quite work for tets since the mesh partitioner will tend
>> to violate that constraint. You could:
>> a) Prescribe the distribution yourself using the Shell
>> partitioner type
>> or
>> b) Write a refiner that turns hexes into tets
>> We already have a refiner that turns tets into hexes, but we
>> never wrote the other direction because it was not clear
>> that it was useful.
>> Thanks,
>> Matt
>> Sincerely,
>> SG
>> experiments is infinitely more interesting than any results to
>> which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191126/dedbd6a8/attachment.html>
