[petsc-users] Petsc Matrix modifications
    Matthew Knepley
    knepley at gmail.com
    Tue Nov 26 09:00:27 CST 2019
On Tue, Nov 26, 2019 at 8:04 AM Brandon Denton <bldenton at buffalo.edu> wrote:
> Good Morning,
> Is it possible to expand a matrix in petsc? I current created and loaded a
> matrix (6 x 5) which holds information required later in my program. I
> would like to store additional information in the matrix by expanding its
> size, let's say make it at 10 x 5 matrix. How is this accomplished in
> petsc. When I try to use MatSetSize() or MatSetValue() my code throws
> errors. What is the process for accomplishing this?
Normally if you change the size, you just make a new object. If you really
want to retain the same pointer
because it is being held by other objects, you can call MatReset() and
rebuild the matrix completely, but
I normally would not do this.
    Matt
> Thank you in advance for your time.
> Brandon
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191126/e7c638a2/attachment.html>
