[petsc-users] problem downloading "fix-syntax-for-nag.tar.gx"
Smith, Barry F. bsmith at mcs.anl.gov
Tue Nov 19 05:49:22 CST 2019
   For a while I had put in an incorrect URL in the download location.
   Perhaps you are using PETSc 3.12.0 and need to use 3.12.1 from  https://www.mcs.anl.gov/petsc/download/index.html
   Otherwise please send configure.log
> On Nov 19, 2019, at 4:40 AM, Santiago Andres Triana via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hello petsc-users:
> I found this error when configure tries to download fblaslapack:
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> Error during download/extract/detection of FBLASLAPACK:
> file could not be opened successfully
> Downloaded package FBLASLAPACK from: https://bitbucket.org/petsc/pkg-fblaslapack/get/origin/barry/2019-08-22/fix-syntax-for-nag.tar.gz is not a tarball.
> [or installed python cannot process compressed files]
> * If you are behind a firewall - please fix your proxy and rerun ./configure
>   For example at LANL you may need to set the environmental variable http_proxy (or HTTP_PROXY?) to  http://proxyout.lanl.gov
> * You can run with --with-packages-download-dir=/adirectory and ./configure will instruct you what packages to download manually
> * or you can download the above URL manually, to /yourselectedlocation/fix-syntax-for-nag.tar.gz
>   and use the configure option:
>   --download-fblaslapack=/yourselectedlocation/fix-syntax-for-nag.tar.gz
> Any ideas? the file in question doesn't seem to exist ... Thanks a lot in advance!
> Santiago
