[petsc-users] problem downloading "fix-syntax-for-nag.tar.gx"
Santiago Andres Triana
repepo at gmail.com
Tue Nov 19 04:40:22 CST 2019
Hello petsc-users:
I found this error when configure tries to download fblaslapack:
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
details):
Error during download/extract/detection of FBLASLAPACK:
file could not be opened successfully
Downloaded package FBLASLAPACK from:
https://bitbucket.org/petsc/pkg-fblaslapack/get/origin/barry/2019-08-22/fix-syntax-for-nag.tar.gz
is not a tarball.
[or installed python cannot process compressed files]
* If you are behind a firewall - please fix your proxy and rerun ./configure
For example at LANL you may need to set the environmental variable
http_proxy (or HTTP_PROXY?) to http://proxyout.lanl.gov
* You can run with --with-packages-download-dir=/adirectory and ./configure
will instruct you what packages to download manually
* or you can download the above URL manually, to
/yourselectedlocation/fix-syntax-for-nag.tar.gz
and use the configure option:
--download-fblaslapack=/yourselectedlocation/fix-syntax-for-nag.tar.gz
Any ideas? the file in question doesn't seem to exist ... Thanks a lot in
advance!
Santiago
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191119/bbd0ed56/attachment.html>
