[petsc-users] VecDuplicate for FFTW-Vec causes VecDestroy to fail conditionally on VecLoad
Zhang, Junchao
jczhang at mcs.anl.gov
Tue Nov 5 11:32:59 CST 2019
Fixed in https://gitlab.com/petsc/petsc/merge_requests/2262
--Junchao Zhang
On Fri, Nov 1, 2019 at 6:51 PM Sajid Ali <sajidsyed2021 at u.northwestern.edu<mailto:sajidsyed2021 at u.northwestern.edu>> wrote:
Hi Junchao/Barry,
It doesn't really matter what the h5 file contains, so I'm attaching a lightly edited script of src/vec/vec/examples/tutorials/ex10.c which should produce a vector to be used as input for the above test case. (I'm working with ` --with-scalar-type=complex`).
Now that I think of it, fixing this bug is not important, I can workaround the issue by creating a new vector with VecCreateMPI and accept the small loss in performance of VecPointwiseMult due to misaligned layouts. If it's a small fix it may be worth the time, but fixing this is not a big priority right now. If it's a complicated fix, this issue can serve as a note to future users.
Thank You,
Sajid Ali
Applied Physics
Northwestern University
s-sajid-ali.github.io<http://s-sajid-ali.github.io>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191105/26e11e15/attachment.html>
