[petsc-users] VecDuplicate for FFTW-Vec causes VecDestroy to fail conditionally on VecLoad
Sajid Ali
sajidsyed2021 at u.northwestern.edu
Fri Nov 1 18:49:56 CDT 2019
Hi Junchao/Barry,
It doesn't really matter what the h5 file contains, so I'm attaching a
lightly edited script of src/vec/vec/examples/tutorials/ex10.c which should
produce a vector to be used as input for the above test case. (I'm working
with ` --with-scalar-type=complex`).
Now that I think of it, fixing this bug is not important, I can workaround
the issue by creating a new vector with VecCreateMPI and accept the small
loss in performance of VecPointwiseMult due to misaligned layouts. If it's
a small fix it may be worth the time, but fixing this is not a big priority
right now. If it's a complicated fix, this issue can serve as a note to
future users.
Thank You,
Sajid Ali
Applied Physics
Northwestern University
s-sajid-ali.github.io
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191101/87b01f8b/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191101/87b01f8b/attachment.obj>
