[petsc-users] Bad memory scaling with PETSc 3.10
Fande Kong fdkong.jd at gmail.com
Wed May 29 10:15:09 CDT 2019
Hi Myriam,
Thanks for your valuable feedback. The plots are really cool! Finally all
the algorithms are scalable.
Fande
On Wed, May 29, 2019 at 8:58 AM Myriam Peyrounette <
myriam.peyrounette at idris.fr> wrote:
> Oh sorry, I missed that. That's great!
> Thanks,
> Myriam
> Le 05/29/19 à 16:55, Zhang, Hong a écrit :
> Myriam:
> This branch is merged to master.
> Thanks for your work and patience. It helps us a lot. The graphs are very
> nice :-)
> We plan to re-organise the APIs of mat-mat opts, make them easier for
> users.
> Hong
>> Hi,
>> Do you have any idea when Barry's fix (
>> https://bitbucket.org/petsc/petsc/pull-requests/1606/change-handling-of-matptap_mpiaij_mpimaij/diff)
>> will be released? I can see it has been merged to the "next" branch. Does
>> it mean it will be soon available on master?
>> +for your information, I plotted a summary of the scalings of interest
>> (memory and time):
>> - using petsc-3.10.2 (ref "bad" scaling)
>> - using petsc-3.6.4 (ref "good" scaling)
>> - using commit d330a26 + Barry's fix and different algorithms (none,
>> scalable, allatonce, allatonce_merged)
>> Best regards,
>> Myriam
>> Le 05/13/19 à 17:20, Fande Kong a écrit :
>> Hi Myriam,
>> Thanks for your report back.
>> On Mon, May 13, 2019 at 2:01 AM Myriam Peyrounette <
>>> Hi all,
>>> I tried with 3.11.1 version and Barry's fix. The good scaling is back!
>>> See the green curve in the plot attached. It is even better than PETSc
>>> 3.6! And it runs faster (10-15s instead of 200-300s with 3.6).
>> We are glad your issue was resolved here.
>>> So you were right. It seems that not all the PtAPs used the scalable
>>> version.
>>> I was a bit confused about the options to set... I used the options:
>>> -matptap_via scalable and -mat_freeintermediatedatastructures 1. Do you
>>> think it would be even better with allatonce?
>> "scalable" and "allatonce" correspond to different algorithms
>> respectively. ``allatonce" should be using less memory than "scalable". The
>> "allatonce" algorithm  would be a good alternative if your application is
>> memory sensitive and the problem size is large.
>> We are definitely curious about the memory usage of ``allatonce" in your
>> test cases but don't feel obligated to do these tests since your concern
>> were resolved now. In case you are also interested in how our new
>> algorithms perform, I post petsc options here that are used to
>> choose these algorithms:
>> algorithm 1: ``allatonce"
>> -matptap_via allatonce
>> algorithm 2: ``allatonce_merged"
>> -matptap_via allatonce_merged
>> Again, thanks for your report that help us improve PETSc.
>> Fande,
>>> It is unfortunate that this fix can't be merged with the master branch.
>>> But the patch works well and I can consider the issue as solved now.
>>> Thanks a lot for your time!
>>> Myriam
>>> Le 05/04/19 à 06:54, Smith, Barry F. a écrit :
>>> >    Hmm, I had already fixed this, I think,
>>> >    but unfortunately our backlog of pull requests kept it out of
>>> master. We are (well Satish and Jed) working on a new CI infrastructure
>>> that will hopefully be more stable than the current CI that we are using.
>>> >    Fande,
>>> >       Sorry you had to spend time on this.
>>> >    Barry
>>> >> On May 3, 2019, at 11:20 PM, Fande Kong via petsc-users <
>>> petsc-users at mcs.anl.gov> wrote:
>>> >> Hi Myriam,
>>> >> I run the example you attached earlier with "-mx 48 -my 48 -mz 48
>>> -levels 3 -ksp_view  -matptap_via allatonce -log_view ".
>>> >> There are six PtAPs. Two of them are sill using the nonscalable
>>> version of the algorithm (this might explain why the memory still
>>> exponentially increases) even though we have asked PETSc to use the
>>> ``allatonce" algorithm. This is happening because MATMAIJ does not honor
>>> the petsc option, instead, it uses the default setting of MPIAIJ.  I have a
>>> fix at
>>> https://bitbucket.org/petsc/petsc/pull-requests/1623/choose-algorithms-in/diff.
>>> The PR should fix the issue.
>>> >> Thanks again for your report,
>>> >> Fande,
>>> Myriam Peyrounette
>>> CNRS/IDRIS - HLST
>> Myriam Peyrounette
>> CNRS/IDRIS - HLST
> Myriam Peyrounette
> CNRS/IDRIS - HLST
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190529/981a57aa/attachment.html>
