[petsc-users] Bad memory scaling with PETSc 3.10
Myriam Peyrounette
myriam.peyrounette at idris.fr
Wed May 29 06:00:24 CDT 2019
Do you have any idea when Barry's fix
(https://bitbucket.org/petsc/petsc/pull-requests/1606/change-handling-of-matptap_mpiaij_mpimaij/diff)
will be released? I can see it has been merged to the "next" branch.
Does it mean it will be soon available on master?
+for your information, I plotted a summary of the scalings of interest
(memory and time):
- using petsc-3.10.2 (ref "bad" scaling)
- using petsc-3.6.4 (ref "good" scaling)
- using commit d330a26 + Barry's fix and different algorithms (none,
scalable, allatonce, allatonce_merged)
Best regards,
Myriam
Le 05/13/19 à 17:20, Fande Kong a écrit :
> Hi Myriam,
> Thanks for your report back.
> On Mon, May 13, 2019 at 2:01 AM Myriam Peyrounette
> <myriam.peyrounette at idris.fr <mailto:myriam.peyrounette at idris.fr>> wrote:
> Hi all,
> I tried with 3.11.1 version and Barry's fix. The good scaling is back!
> See the green curve in the plot attached. It is even better than PETSc
> 3.6! And it runs faster (10-15s instead of 200-300s with 3.6).
> We are glad your issue was resolved here.
> So you were right. It seems that not all the PtAPs used the scalable
> version.
> I was a bit confused about the options to set... I used the options:
> -matptap_via scalable and -mat_freeintermediatedatastructures 1.
> Do you
> think it would be even better with allatonce?
> "scalable" and "allatonce" correspond to different algorithms
> respectively. ``allatonce" should be using less memory than
> "scalable". The "allatonce" algorithm would be a good alternative if
> your application is memory sensitive and the problem size is large.
> We are definitely curious about the memory usage of ``allatonce" in
> your test cases but don't feel obligated to do these tests since your
> concern were resolved now. In case you are also interested in how our
> new algorithms perform, I post petsc options here that are used to
> choose these algorithms:
> algorithm 1: ``allatonce"
> -matptap_via allatonce
> algorithm 2: ``allatonce_merged"
> -matptap_via allatonce_merged
> Again, thanks for your report that help us improve PETSc.
> Fande,
> It is unfortunate that this fix can't be merged with the master
> branch.
> But the patch works well and I can consider the issue as solved now.
> Thanks a lot for your time!
> Myriam
> Le 05/04/19 à 06:54, Smith, Barry F. a écrit :
> > Hmm, I had already fixed this, I think,
> > but unfortunately our backlog of pull requests kept it out of
> master. We are (well Satish and Jed) working on a new CI
> infrastructure that will hopefully be more stable than the current
> CI that we are using.
> > Fande,
> > Sorry you had to spend time on this.
> > Barry
> >> On May 3, 2019, at 11:20 PM, Fande Kong via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> >> Hi Myriam,
> >> I run the example you attached earlier with "-mx 48 -my 48 -mz
> 48 -levels 3 -ksp_view -matptap_via allatonce -log_view ".
> >> There are six PtAPs. Two of them are sill using the nonscalable
> version of the algorithm (this might explain why the memory still
> exponentially increases) even though we have asked PETSc to use
> the ``allatonce" algorithm. This is happening because MATMAIJ does
> not honor the petsc option, instead, it uses the default setting
> of MPIAIJ. I have a fix at
> https://bitbucket.org/petsc/petsc/pull-requests/1623/choose-algorithms-in/diff.
> The PR should fix the issue.
> >> Thanks again for your report,
> >> Fande,
> Myriam Peyrounette
> CNRS/IDRIS - HLST
Myriam Peyrounette
CNRS/IDRIS - HLST
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190529/61bb3c6c/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190529/61bb3c6c/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190529/61bb3c6c/attachment-0003.png>
Type: application/pkcs7-signature
Desc: Signature cryptographique S/MIME
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190529/61bb3c6c/attachment-0001.p7s>
