[petsc-users] Singlar values of the GMRES Hessenberg matrix
Dave Lee
davelee2804 at gmail.com
Mon May 27 06:57:02 CDT 2019
Thanks for the tip Matt, I'll look into it.
Cheers, Dave.
On Mon, May 27, 2019 at 9:53 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, May 27, 2019 at 7:46 AM Dave Lee <davelee2804 at gmail.com> wrote:
>> Thanks Matt, so just to clarify:
>> -- VEC_VV() contains the Krylov subspace vectors (left preconditioned if
>> PC_LEFT) and not the orthonomalized vectors that make up Q_k?
>> - if so, is it possible to obtain Q_k?
>> -- HES(row,col) contains the entries of the Hessenberg matrix
>> corresponding to the Arnoldi iteration for the preconditioned Krylov
>> vectors (if PC_LEFT)?
> Everything in GMRES refers to the preconditioned operator. That is how
> preconditioned GMRES works.
> If you need the unpreconditioned space, you would have to use FGMRES,
> since it pays the storage overhead.
> Thanks,
> Matt
>> Cheers, Dave.
>> On Mon, May 27, 2019 at 8:50 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, May 27, 2019 at 3:55 AM Dave Lee <davelee2804 at gmail.com> wrote:
>>>> Hi Matt and PETSc.
>>>> Thanks again for the advice.
>>>> So I think I know what my problem might be. Looking at the comments
>>>> above the function
>>>> KSPInitialResidual()
>>>> in
>>>> src/ksp/ksp/interface/itres.c
>>>> I see that the initial residual, as passed into VEC_VV(0) is the
>>>> residual of the *preconditioned* system (and that the original
>>>> residual goes temporarily to gmres->vecs[1]).
>>>> So I'm wondering, is the Hessenberg, as derived via the *HES(row,col) macro
>>>> the Hessenberg for the original Krylov subspace, or the preconditioned
>>>> subspace?
>>> Left-preconditioning changes the operator, so you get he Arnoldi
>>> subspace for the transforned operator, starting with a transformed rhs.
>>> Thanks,
>>> Matt
>>>> Secondly, do the vecs within the KSP_GMRES structure, as accessed via
>>>> VEC_VV() correspond to the (preconditioned) Krylov subspace or the
>>>> orthonormalized vectors that make up the matrix Q_k in the Arnoldi
>>>> iteration? This isn't clear to me, and I need to access the vectors in
>>>> Q_k in order to expand the corrected hookstep solution.
>>>> Thanks again, Dave.
>>>> On Sat, May 25, 2019 at 6:18 PM Dave Lee <davelee2804 at gmail.com> wrote:
>>>>> Thanks Matt, this is where I'm adding in my hookstep code.
>>>>> Cheers, Dave.
>>>>> On Fri, May 24, 2019 at 10:49 PM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Fri, May 24, 2019 at 8:38 AM Dave Lee <davelee2804 at gmail.com>
>>>>>> wrote:
>>>>>>> Thanks Matt, great suggestion.
>>>>>>> I did indeed find a transpose error this way. The SVD as
>>>>>>> reconstructed via U S V^T now matches the input Hessenberg matrix as
>>>>>>> derived via the *HES(row,col) macro, and all the singular values
>>>>>>> are non-zero. However the solution to example src/ksp/ksp/examples/tutorials/ex1.c
>>>>>>> as determined via the expansion over the singular vectors is still
>>>>>>> not correct. I suspect I'm doing something wrong with regards to the
>>>>>>> expansion over the vec array VEC_VV(), which I assume are the
>>>>>>> orthonormal vectors of the Q_k matrix in the Arnoldi iteration....
>>>>>> Here we are building the solution:
>>>>>> https://bitbucket.org/petsc/petsc/src/7c23e6aa64ffbff85a2457e1aa154ec3d7f238e3/src/ksp/ksp/impls/gmres/gmres.c#lines-331
>>>>>> There are some subtleties if you have a nonzero initial guess or a
>>>>>> preconditioner.
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> Thanks again for your advice, I'll keep digging.
>>>>>>> Cheers, Dave.
>>>>>>> On Thu, May 23, 2019 at 8:20 PM Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Thu, May 23, 2019 at 5:09 AM Dave Lee via petsc-users <
>>>>>>>> petsc-users at mcs.anl.gov> wrote:
>>>>>>>>> Hi PETSc,
>>>>>>>>> I'm trying to add a "hook step" to the SNES trust region solver
>>>>>>>>> (at the end of the function: KSPGMRESBuildSoln())
>>>>>>>>> I'm testing this using the (linear) example:
>>>>>>>>> as
>>>>>>>>> gdb --args ./test -snes_mf -snes_type newtontr -ksp_rtol 1.0e-12
>>>>>>>>> -snes_stol 1.0e-12 -ksp_converged_reason -snes_converged_reason
>>>>>>>>> -ksp_monitor -snes_monitor
>>>>>>>>> (Ignore the SNES stuff, this is for when I test nonlinear
>>>>>>>>> examples).
>>>>>>>>> When I call the LAPACK SVD routine via PETSc as
>>>>>>>>> PetscStackCallBLAS("LAPACKgesvd",LAPACKgesvd_(...))
>>>>>>>>> I get the following singular values:
>>>>>>>>> 0 KSP Residual norm 7.071067811865e-01
>>>>>>>>> 1 KSP Residual norm 3.162277660168e-01
>>>>>>>>> 2 KSP Residual norm 1.889822365046e-01
>>>>>>>>> 3 KSP Residual norm 1.290994448736e-01
>>>>>>>>> 4 KSP Residual norm 9.534625892456e-02
>>>>>>>>> 5 KSP Residual norm 8.082545620881e-16
>>>>>>>>> 1 0.5 -7.85046e-16 1.17757e-15
>>>>>>>>> 0.5 1 0.5 1.7271e-15
>>>>>>>>> 0 0.5 1 0.5
>>>>>>>>> 0 0 0.5 1
>>>>>>>>> 0 0 0 0.5
>>>>>>>>> singular values: 2.36264 0.409816 1.97794e-15 6.67632e-16
>>>>>>>>> Linear solve converged due to CONVERGED_RTOL iterations 5
>>>>>>>>> Where the lines above the singular values are the Hessenberg
>>>>>>>>> matrix that I'm doing the SVD on.
>>>>>>>> First, write out all the SVD matrices you get and make sure that
>>>>>>>> they reconstruct the input matrix (that
>>>>>>>> you do not have something transposed somewhere).
>>>>>>>> Matt
>>>>>>>>> When I build the solution in terms of the leading two right
>>>>>>>>> singular vectors (and subsequently the first two orthonormal basis vectors
>>>>>>>>> in VECS_VV I get an error norm as:
>>>>>>>>> Norm of error 3.16228, Iterations 5
>>>>>>>>> My suspicion is that I'm creating the Hessenberg incorrectly, as I
>>>>>>>>> would have thought that this problem should have more than two non-zero
>>>>>>>>> leading singular values.
>>>>>>>>> Within my modified version of the GMRES build solution function
>>>>>>>>> (attached) I'm creating this (and passing it to LAPACK as):
>>>>>>>>> nRows = gmres->it+1;
>>>>>>>>> nCols = nRows-1;
>>>>>>>>> ierr = PetscBLASIntCast(nRows,&nRows_blas);CHKERRQ(ierr);
>>>>>>>>> ierr = PetscBLASIntCast(nCols,&nCols_blas);CHKERRQ(ierr);
>>>>>>>>> ierr = PetscBLASIntCast(5*nRows,&lwork);CHKERRQ(ierr);
>>>>>>>>> ierr = PetscMalloc1(5*nRows,&work);CHKERRQ(ierr);
>>>>>>>>> ierr = PetscMalloc1(nRows*nCols,&R);CHKERRQ(ierr);
>>>>>>>>> ierr = PetscMalloc1(nRows*nCols,&H);CHKERRQ(ierr);
>>>>>>>>> for (jj = 0; jj < nRows; jj++) {
>>>>>>>>> for (ii = 0; ii < nCols; ii++) {
>>>>>>>>> R[jj*nCols+ii] = *HES(jj,ii);
>>>>>>>>> // Duplicate the Hessenberg matrix as the one passed to the
>>>>>>>>> SVD solver is destroyed
>>>>>>>>> for (ii=0; ii<nRows*nCols; ii++) H[ii] = R[ii];
>>>>>>>>> ierr = PetscMalloc1(nRows*nRows,&U);CHKERRQ(ierr);
>>>>>>>>> ierr = PetscMalloc1(nCols*nCols,&VT);CHKERRQ(ierr);
>>>>>>>>> ierr = PetscMalloc1(nRows*nRows,&UT);CHKERRQ(ierr);
>>>>>>>>> ierr = PetscMalloc1(nCols*nCols,&V);CHKERRQ(ierr);
>>>>>>>>> ierr = PetscMalloc1(nRows,&p);CHKERRQ(ierr);
>>>>>>>>> ierr = PetscMalloc1(nCols,&q);CHKERRQ(ierr);
>>>>>>>>> ierr = PetscMalloc1(nCols,&y);CHKERRQ(ierr);
>>>>>>>>> // Perform an SVD on the Hessenberg matrix - Note: this call
>>>>>>>>> destroys the input Hessenberg
>>>>>>>>> ierr = PetscFPTrapPush(PETSC_FP_TRAP_OFF);CHKERRQ(ierr);
>>>>>>>>> PetscStackCallBLAS("LAPACKgesvd",LAPACKgesvd_("A","A",&nRows_blas,&nCols_blas,R,&nRows_blas,S,UT,&nRows_blas,V,&nCols_blas,work,&lwork,&lierr));
>>>>>>>>> if (lierr) SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"Error in
>>>>>>>>> SVD Lapack routine %d",(int)lierr);
>>>>>>>>> ierr = PetscFPTrapPop();CHKERRQ(ierr);
>>>>>>>>> // Find the number of non-zero singular values
>>>>>>>>> for(nnz=0; nnz<nCols; nnz++) {
>>>>>>>>> if(fabs(S[nnz]) < 1.0e-8) break;
>>>>>>>>> printf("number of nonzero singular values: %d\n",nnz);
>>>>>>>>> trans(nRows,nRows,UT,U);
>>>>>>>>> trans(nCols,nCols,V,VT);
>>>>>>>>> // Compute p = ||r_0|| U^T e_1
>>>>>>>>> beta = gmres->res_beta;
>>>>>>>>> for (ii=0; ii<nCols; ii++) {
>>>>>>>>> p[ii] = beta*UT[ii*nRows];
>>>>>>>>> p[nCols] = 0.0;
>>>>>>>>> // Original GMRES solution (\mu = 0)
>>>>>>>>> for (ii=0; ii<nnz; ii++) {
>>>>>>>>> q[ii] = p[ii]/S[ii];
>>>>>>>>> // Expand y in terms of the right singular vectors as y = V q
>>>>>>>>> for (jj=0; jj<nnz; jj++) {
>>>>>>>>> y[jj] = 0.0;
>>>>>>>>> y[jj] += V[jj*nCols+ii]*q[ii]; // transpose of the
>>>>>>>>> transpose
>>>>>>>>> // Pass the orthnomalized Krylov vector weights back out
>>>>>>>>> nrs[ii] = y[ii];
>>>>>>>>> I just wanted to check that this is the correct way to extract the
>>>>>>>>> Hessenberg from the KSP_GMRES structure, and to pass it to LAPACK, and if
>>>>>>>>> so, should I really be expecting only two non-zero singular values in
>>>>>>>>> return for this problem?
>>>>>>>>> Cheers, Dave.
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190527/f9183b87/attachment.html>
