[petsc-users] Interpolation using DMInterpolationEvaluate
Swarnava Ghosh
swarnava89 at gmail.com
Thu May 23 14:08:54 CDT 2019
Hi PETSc developers and users,
I am trying to setup a test case of DMInterpolationEvaluate. I am referring
to the example provided in (
https://bitbucket.org/petsc/petsc/src/master/src/snes/examples/tests/ex2.c)
to code it up.
In my case. I have read a mesh from a file created using Gmesh, and I am
trying to interpolate a constant field of ones using
DMInterpolationEvaluate. Since the field is constant, then the interpolated
values should also be the same. However, I am getting other values:
Attached is the code which I wrote to test it:
static char help[] = "Test interpolation\n\
using a parallel unstructured mesh (DMPLEX) to discretize it.\n";
#include <petsctime.h>
#include <mpi.h>
#include <petsc.h>
#include <petscdmda.h>
#include <petscdmplex.h>
#include <petscds.h>
#undef __FUNCT__
#define __FUNCT__ "main"
PetscErrorCode SolveProblem(int i)
PetscBool interpolate=0;
char filename[]="mesh2.msh";
//char filename[]="mesh1";
PetscErrorCode ierr;
DM dm;
DM distributedMesh = NULL;
PetscViewer viewer;
DMLabel label;
PetscBool simplex=PETSC_TRUE;
PetscFE fe;
PetscQuadrature q;
PetscDS prob=NULL;
PetscInt id = 1;
PetscInt order;
PetscPartitioner part;
SNES snes; /* nonlinear solver */
int rank;
Vec fieldvec;
MPI_Comm_rank(MPI_COMM_WORLD,&rank);
// read mesh from file
ierr=DMPlexCreateGmshFromFile(PETSC_COMM_WORLD,filename,interpolate,&dm);CHKERRQ(ierr);
// Distribute mesh over processes
ierr = DMPlexGetPartitioner(dm,&part);CHKERRQ(ierr);
ierr = PetscPartitionerSetFromOptions(part);CHKERRQ(ierr);
ierr = DMPlexDistribute(dm, 0, NULL, &distributedMesh);CHKERRQ(ierr);
if (distributedMesh) {
ierr = DMDestroy(&dm);CHKERRQ(ierr);
dm = distributedMesh;
Vec vcoord;
DMGetCoordinatesLocal(dm,&vcoord);
VecView(vcoord,PETSC_VIEWER_STDOUT_SELF);
// interpolation
PetscInt spaceDim, c, Np=8, p;
DMInterpolationInfo interpolator;
PetscReal pcoords[16];
PetscBool pointsAllProcs=PETSC_TRUE;
Vec lu, fieldVals;
pcoords[0]=0.0; pcoords[1]=0;
pcoords[2]=1; pcoords[3]=0;
pcoords[4]=1; pcoords[5]=1;
pcoords[6]=0; pcoords[7]=1;
pcoords[8]=0.5; pcoords[9]=0.5;
pcoords[10]=2; pcoords[11]=0;
pcoords[12]=2; pcoords[13]=1;
pcoords[14]=1.5; pcoords[15]=0.5;
ierr = DMGetCoordinateDim(dm, &spaceDim);CHKERRQ(ierr);
/* Create interpolator */
ierr = DMInterpolationCreate(PETSC_COMM_WORLD,
&interpolator);CHKERRQ(ierr);
ierr = DMInterpolationSetDim(interpolator, spaceDim);CHKERRQ(ierr);
ierr = DMInterpolationAddPoints(interpolator, Np, pcoords);CHKERRQ(ierr);
//VecGetArray(vcoord,&interpolator->points);
ierr = DMInterpolationSetUp(interpolator, dm,
pointsAllProcs);CHKERRQ(ierr);
/* Check locations */
for (c = 0; c < interpolator->n; ++c) {
ierr = PetscSynchronizedPrintf(PETSC_COMM_WORLD, "[%d]Point %D is in
Cell %D\n", rank, c, interpolator->cells[c]);CHKERRQ(ierr);
ierr = PetscSynchronizedFlush(PETSC_COMM_WORLD, NULL);CHKERRQ(ierr);
ierr = VecView(interpolator->coords,
PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
/* Setup Discretization */
ierr = PetscFECreateDefault(dm, 2, 1, PETSC_TRUE, NULL, -1,
&fe);CHKERRQ(ierr);
ierr = DMSetField(dm, 0, (PetscObject)fe);CHKERRQ(ierr);
// ierr = DMSetDS(dm);CHKERRQ(ierr);
ierr = PetscFEDestroy(&fe);CHKERRQ(ierr);
/* Create function */
ierr = DMGetLocalVector(dm, &lu);CHKERRQ(ierr);
VecSet(lu,1.0);
/* Check interpolant */
ierr = VecCreateSeq(PETSC_COMM_SELF, interpolator->n,
&fieldVals);CHKERRQ(ierr);
VecZeroEntries(fieldVals);
ierr = DMInterpolationSetDof(interpolator, 1);CHKERRQ(ierr);
ierr = DMInterpolationEvaluate(interpolator, dm, lu,
ierr = VecView(fieldVals, PETSC_VIEWER_STDOUT_SELF);CHKERRQ(ierr);
return ierr;
int main(int argc, char **argv)
PetscInitialize(&argc, &argv, (char *) 0, help);
SolveProblem(1);
printf("done \n");
PetscFinalize();
return 0;
The interpolated field at the 8 points defined by pcoords should be all 1s,
and instead I get:
Vec Object: 1 MPI processes
type: seq
1.
0.
0.
0.5
1.
type: seq
-1.5
-1.
2.
Also including the test gmesh file:
$MeshFormat
2.2 0 8
$EndMeshFormat
$PhysicalNames
2
2 1 "left"
2 2 "right"
$EndPhysicalNames
$Nodes
8
1 0 0 0
2 1 0 0
3 1 1 0
4 0 1 0
5 2 0 0
6 2 1 0
7 0.5 0.5 0
8 1.5 0.5 0
$EndNodes
$Elements
8
1 2 2 1 1 1 2 7
2 2 2 1 1 1 7 4
3 2 2 1 1 2 3 7
4 2 2 1 1 3 4 7
5 2 2 2 2 2 8 3
6 2 2 2 2 2 5 8
7 2 2 2 2 3 8 6
8 2 2 2 2 5 6 8
$EndElements
$Periodic
7
0 1 4
1
1 4
0 2 6
1
2 6
0 5 4
1
5 4
0 6 1
1
6 1
1 1 3
0
1 5 7
0
1 6 4
0
$EndPeriodic
Swarnava
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190523/c8b55e96/attachment.html>
