[petsc-users] Question about TSComputeRHSJacobianConstant
Sajid Ali sajidsyed2021 at u.northwestern.edu
Wed May 22 14:26:17 CDT 2019
Hi Hong,
Looks like this is my fault since I'm using -ksp_type preonly -pc_type
gamg. If I use the default ksp (GMRES) then everything works fine on a
smaller problem.
Just to confirm,  -ksp_type preonly is to be used only with direct-solve
preconditioners like LU,Cholesky, right ?
Thank You,
Sajid Ali
Applied Physics
Northwestern University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190522/1b9fd675/attachment.html>
