[petsc-users] PETSc Matrix to MatLab
Zhang, Hong
hzhang at mcs.anl.gov
Fri May 17 10:49:22 CDT 2019
Check your petsc matrix before dumping the data by adding
MatView(A,PETSC_VIEWER_STDOUT_WORLD);
immediately after calling MatAssemblyEnd().
Do you see a correct parallel matrix?
Hong
On Fri, May 17, 2019 at 10:24 AM Emmanuel Ayala via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hello,
I am a newby with PETSc. I want to check some matrices generated in PETSc, using MatLab.
I created a matrix A (MATMPIAIJ), the partition is defined by PETSc and I defined the global size.
Then, I used the next code to save in binary format the matrix from PETSc:
PetscViewer viewer;
PetscViewerBinaryOpen(PETSC_COMM_WORLD, "matrix", FILE_MODE_WRITE, &viewer);
After that (I think) MatView writes in the viewer:
MatView(A,viewer);
Then I laod the matrix in MatLab with PetscBinaryRead().
For one process everything is Ok, I can see the full pattern of the sparse matrix (spy(A)). But when I generate the matrix A with more than one process, the resultant matrix only contains the data from the process 0.
What is the mistake in my procedure?
1. I just want to export the PETSc matrix to MatLab, for any number of process.
Regards.
Thanks in advance, for your time.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190517/d2027fdc/attachment.html>
