[petsc-users] PETSc Matrix to MatLab
Emmanuel Ayala juaneah at gmail.com
Fri May 17 10:19:55 CDT 2019
Hello,
I am a newby with PETSc. I want to check some matrices generated in PETSc,
using MatLab.
I created a matrix A (MATMPIAIJ), the partition is defined by PETSc and I
defined the global size.
Then, I used the next code to save in binary format the matrix from PETSc:
PetscViewer    viewer;
PetscViewerBinaryOpen(PETSC_COMM_WORLD, "matrix", FILE_MODE_WRITE, &viewer);
After that (I think) MatView writes in the viewer:
MatView(A,viewer);
Then I laod the matrix in MatLab with PetscBinaryRead().
For one process everything is Ok, I can see the full pattern of the sparse
matrix (spy(A)). But when I generate the matrix A with more than one
process, the resultant matrix only contains the data from the process 0.
What is the mistake in my procedure?
1. I just want to export the PETSc matrix to MatLab, for any number of
process.
Regards.
Thanks in advance, for your time.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190517/ed1b836b/attachment.html>
