[petsc-users] Question about TSComputeRHSJacobianConstant
    Zhang, Hong
    hongzhang at anl.gov
    Thu May 16 22:33:47 CDT 2019
Hi Sajid,
Can you please try this branch hongzh/fix-computejacobian quickly and see if it makes a difference?
Hong (Mr.)
On May 16, 2019, at 8:04 PM, Sajid Ali via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
While there is a ~3.5X speedup, deleting the aforementioned 20 lines also leads the new version of petsc to give the wrong solution (off by orders of magnitude for the same program).
I tried switching over the the IFunction/IJacobian interface as per the manual (page 146) which the following lines :
TSSetProblemType(ts,TSLINEAR);
TSSetRHSFunction(ts,NULL,TSComputeRHSFunctionLinear,NULL);
TSSetRHSJacobian(ts,A,A,TSComputeRHSJacobianConstant,NULL);
are equivalent to :
TSSetIFunction(ts,NULL,TSComputeIFunctionLinear,NULL);
TSSetIJacobian(ts,A,A,TSComputeIJacobianConstant,NULL);
But the example at src/ts/examples/tutorials/ex3.c employs a strategy of setting a shift flag to prevent re-computation for time-independent problems. Moreover, the docs say "using this function (TSComputeIFunctionLinear) is NOT equivalent to using TSComputeRHSFunctionLinear()" and now I'm even more confused.
PS : Doing the simple switch is as slow as the original code and the answer is wrong as well.
Thank You,
Sajid Ali
Applied Physics
Northwestern University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190517/66f4cc07/attachment.html>
