[petsc-users] Question about TSComputeRHSJacobianConstant
Sajid Ali
sajidsyed2021 at u.northwestern.edu
Thu May 16 20:04:03 CDT 2019
While there is a ~3.5X speedup, deleting the aforementioned 20 lines also
leads the new version of petsc to give the wrong solution (off by orders of
magnitude for the same program).
I tried switching over the the IFunction/IJacobian interface as per the
manual (page 146) which the following lines :
TSSetProblemType(ts,TSLINEAR);
TSSetRHSFunction(ts,NULL,TSComputeRHSFunctionLinear,NULL);
TSSetRHSJacobian(ts,A,A,TSComputeRHSJacobianConstant,NULL);
are equivalent to :
TSSetIFunction(ts,NULL,TSComputeIFunctionLinear,NULL);
TSSetIJacobian(ts,A,A,TSComputeIJacobianConstant,NULL);
But the example at src/ts/examples/tutorials/ex3.c employs a strategy of
setting a shift flag to prevent re-computation for time-independent
problems. Moreover, the docs say "using this function
(TSComputeIFunctionLinear) is NOT equivalent to using
TSComputeRHSFunctionLinear()" and now I'm even more confused.
PS : Doing the simple switch is as slow as the original code and the answer
is wrong as well.
Thank You,
Sajid Ali
Applied Physics
Northwestern University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190516/04de4392/attachment.html>
