[petsc-users] Extremely slow DMNetwork Jacobian assembly
Wed May 8 07:44:21 CDT 2019
On Wed, May 8, 2019 at 4:45 AM Justin Chang via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi guys,
> I have a fully working distribution system solver written using DMNetwork,
> The idea is that each electrical bus can have up to three phase nodes, and
> each phase node has two unknowns: voltage magnitude and angle. In a
> completely balanced system, each bus has three nodes, but in an unbalanced
> system some of the buses can be either single phase or two-phase.
> The working DMNetwork code I developed, loosely based on the SNES
> network/power.c, essentially represents each vertex as a bus.
> DMNetworkAddNumVariables() function will add either 2, 4, or 6 unknowns to
> each vertex. If every single bus had the same number of variables, the mat
> block size = 2, 4, or 6, and my code is both fast and scalable. However, if
> the unknowns per DMNetwork vertex unknowns are not the same across, then my
> SNESFormJacobian function becomes extremely extremely slow. Specifically,
> the MatSetValues() calls when the col/row global indices contain an offset
> value that points to a neighboring bus vertex.
I have never seen MatSetValues() be slow unless it is allocating. Did you
confirm that you are not allocating, with -info?
     MAtt
> Why is that? Is it because I no longer have a uniform block structure and
> lose the speed/optimization benefits of iterating through an AIJ matrix? I
> see three potential workarounds:
> 1) Treat every vertex as a three phase bus and "zero out" all the unused
> phase node dofs and put a 1 in the diagonal. The problem I see with this is
> that I will have unnecessary degrees of freedom (aka non-zeros in the
> matrix). From the distribution systems I've seen, it's possible that
>  anywhere from 1/3 to 1/2 of the buses will be two-phase or less, meaning I
> may have nearly twice the amount of dofs than necessary if I wanted to
> preserve the block size = 6 for the AU mat.
> 2) Treat every phase node as a vertex aka solve a single-phase power flow
> solver. That way I guarantee to have a block size = 2, this is what
> Domenico's former student did in his thesis work. The problem I see with
> this is that I have a larger graph, which can take more time to setup and
> parallelize.
> 3) Create a "fieldsplit" where I essentially have three "blocks" - one for
> buses with all three phases, another for buses with only two phases, one
> for single-phase buses. This way each block/fieldsplit will have a
> consistent block size. I am not sure if this will solve the MatSetValues()
> issues, but it's, but can anyone give pointers on how to go about achieving
> this?
> Thanks,
> Justin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190508/5972547b/attachment.html>
