[petsc-users] Extremely slow DMNetwork Jacobian assembly
Justin Chang
jychang48 at gmail.com
Wed May 8 03:44:15 CDT 2019
Hi guys,
I have a fully working distribution system solver written using DMNetwork,
The idea is that each electrical bus can have up to three phase nodes, and
each phase node has two unknowns: voltage magnitude and angle. In a
completely balanced system, each bus has three nodes, but in an unbalanced
system some of the buses can be either single phase or two-phase.
The working DMNetwork code I developed, loosely based on the SNES
network/power.c, essentially represents each vertex as a bus.
DMNetworkAddNumVariables() function will add either 2, 4, or 6 unknowns to
each vertex. If every single bus had the same number of variables, the mat
block size = 2, 4, or 6, and my code is both fast and scalable. However, if
the unknowns per DMNetwork vertex unknowns are not the same across, then my
SNESFormJacobian function becomes extremely extremely slow. Specifically,
the MatSetValues() calls when the col/row global indices contain an offset
value that points to a neighboring bus vertex.
Why is that? Is it because I no longer have a uniform block structure and
lose the speed/optimization benefits of iterating through an AIJ matrix? I
see three potential workarounds:
1) Treat every vertex as a three phase bus and "zero out" all the unused
phase node dofs and put a 1 in the diagonal. The problem I see with this is
that I will have unnecessary degrees of freedom (aka non-zeros in the
matrix). From the distribution systems I've seen, it's possible that
anywhere from 1/3 to 1/2 of the buses will be two-phase or less, meaning I
may have nearly twice the amount of dofs than necessary if I wanted to
preserve the block size = 6 for the AU mat.
2) Treat every phase node as a vertex aka solve a single-phase power flow
solver. That way I guarantee to have a block size = 2, this is what
Domenico's former student did in his thesis work. The problem I see with
this is that I have a larger graph, which can take more time to setup and
parallelize.
3) Create a "fieldsplit" where I essentially have three "blocks" - one for
buses with all three phases, another for buses with only two phases, one
for single-phase buses. This way each block/fieldsplit will have a
consistent block size. I am not sure if this will solve the MatSetValues()
issues, but it's, but can anyone give pointers on how to go about achieving
this?
Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190508/b52d6dc5/attachment-0001.html>
