[petsc-users] ``--with-clanguage=c++" turns on "PETSC_HAVE_COMPLEX"?
Balay, Satish
balay at mcs.anl.gov
Fri May 3 20:29:08 CDT 2019
Executing: mpicxx -show stdout: clang -I/Users/kongf/projects/openmpi-2.1.1_installed/include -L/Users/kongf/projects/openmpi-2.1.1_installed/lib -lmpi
Hm - I think this [specifying a C compiler as c++] is the trigger of this problem.
configure checks if the c++ compiler supports complex. This test was successful [as it was done with .cxx file - and presumably clang switches to c++ mocd for a .cxx file.
However PETSc sources a .c - so its likely compiling PETSc as C - so things are now inconsistant - and broken..
Note:
PETSC_HAVE_COMPLEX => compilers support complex - so define a complex datatype
PETSC_USE_COMPLEX => build PETSc with PetscScalar=complex
Satish
On Fri, 3 May 2019, Fande Kong via petsc-users wrote:
> Hi All,
> Comping PETSc with ``--with-clanguage=c" works fine. But I could not
> compile PETSc with "--with-clanguage=c++" since the flag
> "PETSC_HAVE_COMPLEX" was wrongly set on by this option.
> */Users/kongf/projects/petsc/src/sys/objects/pinit.c:913:21: error:
> expected parameter declarator*
> * PetscComplex ic(0.0,1.0);*
> expected ')'*
> */Users/kongf/projects/petsc/src/sys/objects/pinit.c:913:20: note: to match
> this '('*
> */Users/kongf/projects/petsc/src/sys/objects/pinit.c:914:13: error:
> assigning to 'PetscComplex' (aka '_Complex double') from incompatible type
> 'PetscComplex ()' (aka '_Complex double ()')*
> * PETSC_i = ic;*
> *3 errors generated.*
> *make[2]: *** [arch-linux2-c-opt-memory/obj/sys/objects/pinit.o] Error 1*
> *make[2]: *** Waiting for unfinished jobs....*
> *make[2]: Leaving directory `/Users/kongf/projects/petsc'*
> *make[1]: *** [gnumake] Error 2*
> *make[1]: Leaving directory `/Users/kongf/projects/petsc'*
> ***************************ERROR**************************************
> * Error during compile, check
> arch-linux2-c-opt-memory/lib/petsc/conf/make.log*
> * Send it and arch-linux2-c-opt-memory/lib/petsc/conf/configure.log to
> petsc-maint at mcs.anl.gov <petsc-maint at mcs.anl.gov>*
> The make and configure logs are attached.
> Fande,
