[petsc-users] ``--with-clanguage=c++" turns on "PETSC_HAVE_COMPLEX"?
Fande Kong
fdkong.jd at gmail.com
Fri May 3 20:00:36 CDT 2019
Hi All,
Comping PETSc with ``--with-clanguage=c" works fine. But I could not
compile PETSc with "--with-clanguage=c++" since the flag
"PETSC_HAVE_COMPLEX" was wrongly set on by this option.
*/Users/kongf/projects/petsc/src/sys/objects/pinit.c:913:21: error:
expected parameter declarator*
* PetscComplex ic(0.0,1.0);*
expected ')'*
*/Users/kongf/projects/petsc/src/sys/objects/pinit.c:913:20: note: to match
this '('*
*/Users/kongf/projects/petsc/src/sys/objects/pinit.c:914:13: error:
assigning to 'PetscComplex' (aka '_Complex double') from incompatible type
'PetscComplex ()' (aka '_Complex double ()')*
* PETSC_i = ic;*
*3 errors generated.*
*make[2]: *** [arch-linux2-c-opt-memory/obj/sys/objects/pinit.o] Error 1*
*make[2]: *** Waiting for unfinished jobs....*
*make[2]: Leaving directory `/Users/kongf/projects/petsc'*
*make[1]: *** [gnumake] Error 2*
*make[1]: Leaving directory `/Users/kongf/projects/petsc'*
***************************ERROR**************************************
* Error during compile, check
arch-linux2-c-opt-memory/lib/petsc/conf/make.log*
* Send it and arch-linux2-c-opt-memory/lib/petsc/conf/configure.log to
petsc-maint at mcs.anl.gov <petsc-maint at mcs.anl.gov>*
The make and configure logs are attached.
Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190503/c22d44aa/attachment-0001.html>
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190503/c22d44aa/attachment-0002.zip>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190503/c22d44aa/attachment-0003.zip>
