[petsc-users] Bad memory scaling with PETSc 3.10
Myriam Peyrounette
myriam.peyrounette at idris.fr
Wed Mar 27 04:10:02 CDT 2019
Hi all,
for your information, you'll find attached the comparison of the weak
memory scalings when using :
- PETSc 3.6.4 (reference)
- PETSc 3.10.4 without specific options
- PETSc 3.10.4 with the three scalability options you mentionned
Using the scalability options does improve the memory scaling. However,
the 3.6 version still has a better one...
Myriam
Le 03/26/19 à 16:16, Myriam Peyrounette a écrit :
> *SetFromOptions() was not called indeed... Thanks! The code
> performance is better now with regard to memory usage!
> I still have to plot the memory scaling on bigger cases to see if it
> has the same good behaviour as when using the 3.6 version.
> I'll let ou know as soon as I have plotted it.
> Thanks again
> Myriam
> Le 03/26/19 à 14:30, Matthew Knepley a écrit :
>> On Tue, Mar 26, 2019 at 9:27 AM Myriam Peyrounette
>> <myriam.peyrounette at idris.fr <mailto:myriam.peyrounette at idris.fr>> wrote:
>> I checked with -ksp_view (attached) but no prefix is associated
>> with the matrix. Some are associated to the KSP and PC, but none
>> to the Mat
>> Another thing that could prevent options being used is that
>> *SetFromOptions() is not called for the object.
>> Thanks,
>> Matt
>> Le 03/26/19 à 11:55, Dave May a écrit :
>>> On Tue, 26 Mar 2019 at 10:36, Myriam Peyrounette
>>> Oh you were right, the three options are unsused
>>> (-matptap_via scalable, -inner_offdiag_matmatmult_via
>>> scalable and -inner_diag_matmatmult_via scalable). Does this
>>> mean I am not using the associated PtAP functions?
>>> No - not necessarily. All it means is the options were not parsed.
>>> If your matrices have an option prefix associated with them
>>> (e.g. abc) , then you need to provide the option as
>>> -abc_matptap_via scalable
>>> If you are not sure if you matrices have a prefix, look at the
>>> result of -ksp_view (see below for an example)
>>> Mat Object: 2 MPI processes
>>> type: mpiaij
>>> rows=363, cols=363, bs=3
>>> total: nonzeros=8649, allocated nonzeros=8649
>>> total number of mallocs used during MatSetValues calls =0
>>> Mat Object: (B_) 2 MPI processes
>>> type: mpiaij
>>> The first matrix has no options prefix, but the second does and
>>> it's called "B_".
>>> Myriam
>>> Le 03/26/19 à 11:10, Dave May a écrit :
>>>> On Tue, 26 Mar 2019 at 09:52, Myriam Peyrounette via
>>>> petsc-users <petsc-users at mcs.anl.gov
>>>> <mailto:petsc-users at mcs.anl.gov>> wrote:
>>>> How can I be sure they are indeed used? Can I print
>>>> this information in some log file?
>>>> Yes. Re-run the job with the command line option
>>>> -options_left true
>>>> This will report all options parsed, and importantly, will
>>>> also indicate if any options were unused.
>>>> Thanks
>>>> Dave
>>>> Thanks in advance
>>>> Myriam
>>>> Le 03/25/19 à 18:24, Matthew Knepley a écrit :
>>>>> On Mon, Mar 25, 2019 at 10:54 AM Myriam Peyrounette
>>>>> via petsc-users <petsc-users at mcs.anl.gov
>>>>> Hi,
>>>>> thanks for the explanations. I tried the last
>>>>> PETSc version (commit
>>>>> fbc5705bc518d02a4999f188aad4ccff5f754cbf), which
>>>>> includes the patch you talked about. But the
>>>>> memory scaling shows no improvement (see scaling
>>>>> attached), even when using the "scalable" options :(
>>>>> I had a look at the PETSc functions
>>>>> MatPtAPNumeric_MPIAIJ_MPIAIJ and
>>>>> MatPtAPSymbolic_MPIAIJ_MPIAIJ (especially at the
>>>>> differences before and after the first "bad"
>>>>> commit), but I can't find what induced this memory
>>>>> issue.
>>>>> Are you sure that the option was used? It just looks
>>>>> suspicious to me that they use exactly the same amount
>>>>> of memory. It should be different, even if it does not
>>>>> solve the problem.
>>>>> Thanks,
>>>>> Matt
>>>>> Myriam
>>>>> Le 03/20/19 à 17:38, Fande Kong a écrit :
>>>>>> Hi Myriam,
>>>>>> There are three algorithms in PETSc to do PtAP
>>>>>> ( const char *algTypes[3] =
>>>>>> {"scalable","nonscalable","hypre"};), and can be
>>>>>> specified using the petsc options: -matptap_via xxxx.
>>>>>> (1) -matptap_via hypre: This call the hypre
>>>>>> package to do the PtAP trough an all-at-once
>>>>>> triple product. In our experiences, it is the
>>>>>> most memory efficient, but could be slow.
>>>>>> (2) -matptap_via scalable: This involves a
>>>>>> row-wise algorithm plus an outer product. This
>>>>>> will use more memory than hypre, but way faster.
>>>>>> This used to have a bug that could take all your
>>>>>> memory, and I have a fix
>>>>>> at https://bitbucket.org/petsc/petsc/pull-requests/1452/mpiptap-enable-large-scale-simulations/diff.
>>>>>> When using this option, we may want to have extra
>>>>>> options such as -inner_offdiag_matmatmult_via
>>>>>> scalable -inner_diag_matmatmult_via scalable to
>>>>>> select inner scalable algorithms.
>>>>>> (3) -matptap_via nonscalable: Suppose to be
>>>>>> even faster, but use more memory. It does dense
>>>>>> matrix operations.
>>>>>> Thanks,
>>>>>> Fande Kong
>>>>>> On Wed, Mar 20, 2019 at 10:06 AM Myriam
>>>>>> Peyrounette via petsc-users
>>>>>> More precisely: something happens when
>>>>>> upgrading the functions
>>>>>> MatPtAPNumeric_MPIAIJ_MPIAIJ and/or
>>>>>> MatPtAPSymbolic_MPIAIJ_MPIAIJ.
>>>>>> Unfortunately, there are a lot of differences
>>>>>> between the old and new versions of these
>>>>>> functions. I keep investigating but if you
>>>>>> have any idea, please let me know.
>>>>>> Best,
>>>>>> Myriam
>>>>>> Le 03/20/19 à 13:48, Myriam Peyrounette a écrit :
>>>>>>> Hi all,
>>>>>>> I used git bisect to determine when the
>>>>>>> memory need increased. I found that the
>>>>>>> first "bad" commit is
>>>>>>> aa690a28a7284adb519c28cb44eae20a2c131c85.
>>>>>>> Barry was right, this commit seems to be
>>>>>>> about an evolution of
>>>>>>> MatPtAPSymbolic_MPIAIJ_MPIAIJ. You mentioned
>>>>>>> the option "-matptap_via scalable" but I
>>>>>>> can't find any information about it. Can you
>>>>>>> tell me more?
>>>>>>> Thanks
>>>>>>> Myriam
>>>>>>> Le 03/11/19 à 14:40, Mark Adams a écrit :
>>>>>>>> Is there a difference in memory usage on
>>>>>>>> your tiny problem? I assume no.
>>>>>>>> I don't see anything that could come from
>>>>>>>> GAMG other than the RAP stuff that you have
>>>>>>>> discussed already.
>>>>>>>> On Mon, Mar 11, 2019 at 9:32 AM Myriam
>>>>>>>> Peyrounette <myriam.peyrounette at idris.fr
>>>>>>>> The code I am using here is the example
>>>>>>>> 42 of PETSc
>>>>>>>> (https://www.mcs.anl.gov/petsc/petsc-3.9/src/ksp/ksp/examples/tutorials/ex42.c.html).
>>>>>>>> Indeed it solves the Stokes equation. I
>>>>>>>> thought it was a good idea to use an
>>>>>>>> example you might know (and didn't find
>>>>>>>> any that uses GAMG functions). I just
>>>>>>>> changed the PCMG setup so that the
>>>>>>>> memory problem appears. And it appears
>>>>>>>> when adding PCGAMG.
>>>>>>>> I don't care about the performance or
>>>>>>>> even the result rightness here, but
>>>>>>>> only about the difference in memory use
>>>>>>>> between 3.6 and 3.10. Do you think
>>>>>>>> finding a more adapted script would help?
>>>>>>>> I used the threshold of 0.1 only once,
>>>>>>>> at the beginning, to test its
>>>>>>>> influence. I used the default threshold
>>>>>>>> (of 0, I guess) for all the other runs.
>>>>>>>> Myriam
>>>>>>>> Le 03/11/19 à 13:52, Mark Adams a écrit :
>>>>>>>>> In looking at this larger scale run ...
>>>>>>>>> * Your eigen estimates are much lower
>>>>>>>>> than your tiny test problem. But this
>>>>>>>>> is Stokes apparently and it should not
>>>>>>>>> work anyway. Maybe you have a small
>>>>>>>>> time step that adds a lot of mass that
>>>>>>>>> brings the eigen estimates down. And
>>>>>>>>> your min eigenvalue (not used) is
>>>>>>>>> positive. I would expect negative for
>>>>>>>>> Stokes ...
>>>>>>>>> * You seem to be setting a threshold
>>>>>>>>> value of 0.1 -- that is very high
>>>>>>>>> * v3.6 says "using nonzero initial
>>>>>>>>> guess" but this is not in v3.10. Maybe
>>>>>>>>> we just stopped printing that.
>>>>>>>>> * There were some changes to coasening
>>>>>>>>> parameters in going from v3.6 but it
>>>>>>>>> does not look like your problem was
>>>>>>>>> effected. (The coarsening algo is
>>>>>>>>> non-deterministic by default and you
>>>>>>>>> can see small difference on different
>>>>>>>>> runs)
>>>>>>>>> * We may have also added a "noisy" RHS
>>>>>>>>> for eigen estimates by default from v3.6.
>>>>>>>>> * And for non-symetric problems you
>>>>>>>>> can try -pc_gamg_agg_nsmooths 0, but
>>>>>>>>> again GAMG is not built for Stokes anyway.
>>>>>>>>> On Tue, Mar 5, 2019 at 11:53 AM Myriam
>>>>>>>>> Peyrounette
>>>>>>>>> wrote:
>>>>>>>>> I used PCView to display the size
>>>>>>>>> of the linear system in each level
>>>>>>>>> of the MG. You'll find the outputs
>>>>>>>>> attached to this mail (zip file)
>>>>>>>>> for both the default threshold
>>>>>>>>> value and a value of 0.1, and for
>>>>>>>>> both 3.6 and 3.10 PETSc versions.
>>>>>>>>> For convenience, I summarized the
>>>>>>>>> information in a graph, also
>>>>>>>>> attached (png file).
>>>>>>>>> As you can see, there are slight
>>>>>>>>> differences between the two
>>>>>>>>> versions but none is critical, in
>>>>>>>>> my opinion. Do you see anything
>>>>>>>>> suspicious in the outputs?
>>>>>>>>> + I can't find the default
>>>>>>>>> threshold value. Do you know where
>>>>>>>>> I can find it?
>>>>>>>>> Thanks for the follow-up
>>>>>>>>> Myriam
>>>>>>>>> Le 03/05/19 à 14:06, Matthew
>>>>>>>>> Knepley a écrit :
>>>>>>>>>> On Tue, Mar 5, 2019 at 7:14 AM
>>>>>>>>>> Myriam Peyrounette
>>>>>>>>>> wrote:
>>>>>>>>>> Hi Matt,
>>>>>>>>>> I plotted the memory scalings
>>>>>>>>>> using different threshold
>>>>>>>>>> values. The two scalings are
>>>>>>>>>> slightly translated (from -22
>>>>>>>>>> to -88 mB) but this gain is
>>>>>>>>>> neglectable. The 3.6-scaling
>>>>>>>>>> keeps being robust while the
>>>>>>>>>> 3.10-scaling deteriorates.
>>>>>>>>>> Do you have any other suggestion?
>>>>>>>>>> Mark, what is the option she can
>>>>>>>>>> give to output all the GAMG data?
>>>>>>>>>> Also, run using -ksp_view. GAMG
>>>>>>>>>> will report all the sizes of its
>>>>>>>>>> grids, so it should be easy to see
>>>>>>>>>> if the coarse grid sizes are
>>>>>>>>>> increasing, and also what the
>>>>>>>>>> effect of the threshold value is.
>>>>>>>>>> Thanks,
>>>>>>>>>> Matt
>>>>>>>>>> Thanks
>>>>>>>>>> Myriam
>>>>>>>>>> Le 03/02/19 à 02:27, Matthew
>>>>>>>>>> Knepley a écrit :
>>>>>>>>>>> On Fri, Mar 1, 2019 at 10:53
>>>>>>>>>>> AM Myriam Peyrounette via
>>>>>>>>>>> petsc-users
>>>>>>>>>>> wrote:
>>>>>>>>>>> Hi,
>>>>>>>>>>> I used to run my code
>>>>>>>>>>> with PETSc 3.6. Since I
>>>>>>>>>>> upgraded the PETSc version
>>>>>>>>>>> to 3.10, this code has a
>>>>>>>>>>> bad memory scaling.
>>>>>>>>>>> To report this issue, I
>>>>>>>>>>> took the PETSc script
>>>>>>>>>>> ex42.c and slightly
>>>>>>>>>>> modified it so that the
>>>>>>>>>>> KSP and PC
>>>>>>>>>>> configurations are the
>>>>>>>>>>> same as in my
>>>>>>>>>>> code. In particular, I
>>>>>>>>>>> use a "personnalised"
>>>>>>>>>>> multi-grid method. The
>>>>>>>>>>> modifications are
>>>>>>>>>>> indicated by the keyword
>>>>>>>>>>> "TopBridge" in the attached
>>>>>>>>>>> scripts.
>>>>>>>>>>> To plot the memory
>>>>>>>>>>> (weak) scaling, I ran
>>>>>>>>>>> four calculations for each
>>>>>>>>>>> script with increasing
>>>>>>>>>>> problem sizes and
>>>>>>>>>>> computations cores:
>>>>>>>>>>> 1. 100,000 elts on 4 cores
>>>>>>>>>>> 2. 1 million elts on 40
>>>>>>>>>>> cores
>>>>>>>>>>> 3. 10 millions elts on
>>>>>>>>>>> 400 cores
>>>>>>>>>>> 4. 100 millions elts on
>>>>>>>>>>> 4,000 cores
>>>>>>>>>>> The resulting graph is
>>>>>>>>>>> also attached. The
>>>>>>>>>>> scaling using PETSc 3.10
>>>>>>>>>>> clearly deteriorates for
>>>>>>>>>>> large cases, while the
>>>>>>>>>>> one using PETSc 3.6 is
>>>>>>>>>>> robust.
>>>>>>>>>>> After a few tests, I
>>>>>>>>>>> found that the scaling
>>>>>>>>>>> is mostly sensitive to the
>>>>>>>>>>> use of the AMG method
>>>>>>>>>>> for the coarse grid
>>>>>>>>>>> (line 1780 in
>>>>>>>>>>> main_ex42_petsc36.cc).
>>>>>>>>>>> In particular, the
>>>>>>>>>>> performance strongly
>>>>>>>>>>> deteriorates when
>>>>>>>>>>> commenting lines 1777 to
>>>>>>>>>>> 1790 (in
>>>>>>>>>>> Do you have any idea of
>>>>>>>>>>> what changed between
>>>>>>>>>>> version 3.6 and version
>>>>>>>>>>> 3.10 that may imply such
>>>>>>>>>>> degradation?
>>>>>>>>>>> I believe the default values
>>>>>>>>>>> for PCGAMG changed between
>>>>>>>>>>> versions. It sounds like the
>>>>>>>>>>> coarsening rate
>>>>>>>>>>> is not great enough, so that
>>>>>>>>>>> these grids are too large.
>>>>>>>>>>> This can be set using:
>>>>>>>>>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGAMGSetThreshold.html
>>>>>>>>>>> There is some explanation of
>>>>>>>>>>> this effect on that page.
>>>>>>>>>>> Let us know if setting this
>>>>>>>>>>> does not correct the situation.
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Matt
>>>>>>>>>>> Let me know if you need
>>>>>>>>>>> further information.
>>>>>>>>>>> Best,
>>>>>>>>>>> Myriam Peyrounette
>>>>>>>>>>> Myriam Peyrounette
>>>>>>>>>>> CNRS/IDRIS - HLST
>>>>>>>>>>> What most experimenters take
>>>>>>>>>>> for granted before they
>>>>>>>>>>> begin their experiments is
>>>>>>>>>>> infinitely more interesting
>>>>>>>>>>> than any results to which
>>>>>>>>>>> their experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>> <http://www.cse.buffalo.edu/%7Eknepley/>
>>>>>>>>>> Myriam Peyrounette
>>>>>>>>>> CNRS/IDRIS - HLST
>>>>>>>>>> What most experimenters take for
>>>>>>>>>> granted before they begin their
>>>>>>>>>> experiments is infinitely more
>>>>>>>>>> interesting than any results to
>>>>>>>>>> which their experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> Myriam Peyrounette
>>>>>>>>> CNRS/IDRIS - HLST
>>>>>>>> Myriam Peyrounette
>>>>>>>> CNRS/IDRIS - HLST
>>>>>>> Myriam Peyrounette
>>>>>>> CNRS/IDRIS - HLST
>>>>>> Myriam Peyrounette
>>>>>> CNRS/IDRIS - HLST
>>>>> Myriam Peyrounette
>>>>> CNRS/IDRIS - HLST
>>>>> What most experimenters take for granted before they
>>>>> begin their experiments is infinitely more interesting
>>>>> than any results to which their experiments lead.
>>>>> -- Norbert Wiener
>>>> Myriam Peyrounette
>>>> CNRS/IDRIS - HLST
>>> Myriam Peyrounette
>>> CNRS/IDRIS - HLST
>> Myriam Peyrounette
>> CNRS/IDRIS - HLST
>> experiments is infinitely more interesting than any results to which
>> -- Norbert Wiener
> Myriam Peyrounette
> CNRS/IDRIS - HLST
Myriam Peyrounette
CNRS/IDRIS - HLST
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190327/952ca79b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190327/952ca79b/attachment-0001.png>
Type: application/pkcs7-signature
Desc: Signature cryptographique S/MIME
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190327/952ca79b/attachment-0001.p7s>
