[petsc-users] Direct PETSc to use MCDRAM on KNL and other optimizations for KNL
Sajid Ali sajidsyed2021 at u.northwestern.edu
Fri Mar 1 13:00:53 CST 2019
Hi Hong,
So, the speedup was coming from increased DRAM bandwidth and not the usage
of MCDRAM.
There is moderate MPI imbalance, large amount of Back-End stalls and good
vectorization.
I'm attaching my submit script, PETSc log file and Intel APS summary (all
as non-HTML text). I can give more detailed analysis via Intel Vtune if
needed.
Thank You,
Sajid Ali
Applied Physics
Northwestern University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190301/f2f5f17a/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190301/f2f5f17a/attachment-0003.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190301/f2f5f17a/attachment-0004.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190301/f2f5f17a/attachment-0005.obj>
