[petsc-users] [Ext] Re: error: identifier "MatCreateMPIAIJMKL" is undefined in 3.10.4
Kun Jiao
KJiao at slb.com
Tue Mar 26 14:00:13 CDT 2019
Strange things, when I compile my code in the test dir in PETSC, it works. After I "make install" PETSC, and try to compile my code against the installed PETSC, it doesn't work any more.
I guess this is what you means.
Is there any way to reenable MatCreateMPIAIJMKL public interface?
And, I am using intel MKL, here is my configure option:
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions PETSC_ARCH=linux-gnu-intel --with-precision=single --with-cc=mpiicc --with-cxx=mpiicc --with-fc=mpiifort --with-mpi-include=/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel/compilers_and_libraries_2019.2.187/linux/mpi/intel64/include --with-mpi-lib="-L/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel//compilers_and_libraries_2019.2.187/linux/mpi/intel64/lib -lmpifort -lmpi_ilp64" --with-blaslapack-lib="-L/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel/compilers_and_libraries_2019.2.187/linux/mkl/lib/intel64 -Wl, --no-as-needed -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lm -ldl" --with-scalapack-lib="-L/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel/compilers_and_libraries_2019.2.187/linux/mkl/lib/intel64 -lmkl_scalapack_lp64 -lmkl_blacs_intelmpi_lp64" --with-scalapack-include=/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel/compilers_and_libraries_2019.2.187/linux/mkl/include --with-mkl_pardiso-dir=/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel/compilers_and_libraries_2019.2.187/linux/mkl --with-mkl_sparse=1 --with-mkl_sparse-dir=/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel/compilers_and_libraries_2019.2.187/linux/mkl --with-mkl_cpardiso=1 --with-mkl_cpardiso-dir=/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel/compilers_and_libraries_2019.2.187/linux/mkl --with-mkl_sparse_optimize=1 --with-mkl_sparse_optimize-dir=/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel/compilers_and_libraries_2019.2.187/linux/mkl --with-mkl_sparse_sp2m=1 --with-mkl_sparse_sp2m-dir=/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel/compilers_and_libraries_2019.2.187/linux/mkl --with-cmake=1 --prefix=/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/petsc_3.9.4 --known-endian=big --with-debugging=0 --COPTFLAGS=" -Ofast -xHost" --CXXOPTFLAGS=" -Ofast -xHost" --FOPTFLAGS=" -Ofast -xHost" --with-x=0
Working directory: /wgdisk/hy3300/source_code_dev/imaging/kjiao/petsc-3.10.4
Schlumberger-Private
-----Original Message-----
Sent: Tuesday, March 26, 2019 10:19 AM
To: Kun Jiao <KJiao at slb.com>
Cc: Mark Adams <mfadams at lbl.gov>; petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] [Ext] Re: error: identifier "MatCreateMPIAIJMKL" is undefined in 3.10.4
balay at sb /home/balay/petsc (maint=)
$ git grep MatCreateMPIAIJMKL maint-3.8
maint-3.8:src/mat/impls/aij/mpi/aijmkl/mpiaijmkl.c: MatCreateMPIAIJMKL - Creates a sparse parallel matrix whose local
maint-3.8:src/mat/impls/aij/mpi/aijmkl/mpiaijmkl.c:PetscErrorCode MatCreateMPIAIJMKL(MPI_Comm comm,PetscInt m,PetscInt n,PetscInt M,PetscInt N,PetscInt d_nz,const PetscInt d_nnz[],PetscInt o_nz,const PetscInt o_nnz[],Mat *A)
maint-3.8:src/mat/impls/aij/mpi/aijmkl/mpiaijmkl.c:.seealso: MatCreateMPIAIJMKL(), MATSEQAIJMKL, MATMPIAIJMKL
maint-3.8:src/mat/impls/aij/seq/aijmkl/aijmkl.c:.seealso: MatCreate(), MatCreateMPIAIJMKL(), MatSetValues() balay at sb /home/balay/petsc (maint=) $ git grep MatCreateMPIAIJMKL maint
maint:src/mat/impls/aij/mpi/aijmkl/mpiaijmkl.c: MatCreateMPIAIJMKL - Creates a sparse parallel matrix whose local
maint:src/mat/impls/aij/mpi/aijmkl/mpiaijmkl.c:PetscErrorCode MatCreateMPIAIJMKL(MPI_Comm comm,PetscInt m,PetscInt n,PetscInt M,PetscInt N,PetscInt d_nz,const PetscInt d_nnz[],PetscInt o_nz,const PetscInt o_nnz[],Mat *A)
maint:src/mat/impls/aij/mpi/aijmkl/mpiaijmkl.c:.seealso: MatCreateMPIAIJMKL(), MATSEQAIJMKL, MATMPIAIJMKL
maint:src/mat/impls/aij/seq/aijmkl/aijmkl.c:.seealso: MatCreate(), MatCreateMPIAIJMKL(), MatSetValues() balay at sb /home/balay/petsc (maint=) $ <<<<<<<<<<<
MatCreateMPIAIJMKL() exists in both petsc-3.8 and petsc-3.10. However the public interface is missing from both of these versions. So I'm surprised you don't get the same error with petsc-3.8
Can you try the following change?
diff --git a/include/petscmat.h b/include/petscmat.h index 1b8ac69377..c66f727994 100644
--- a/include/petscmat.h
+++ b/include/petscmat.h
@@ -223,7 +223,8 @@ typedef enum {DIFFERENT_NONZERO_PATTERN,SUBSET_NONZERO_PATTERN,SAME_NONZERO_PATT
#if defined PETSC_HAVE_MKL_SPARSE
PETSC_EXTERN PetscErrorCode MatCreateBAIJMKL(MPI_Comm,PetscInt,PetscInt,PetscInt,PetscInt,PetscInt,PetscInt,const PetscInt[],PetscInt,const PetscInt[],Mat*); -PETSC_EXTERN PetscErrorCode MatCreateSeqBAIJMKL(MPI_Comm comm,PetscInt bs,PetscInt m,PetscInt n,PetscInt nz,const PetscInt nnz[],Mat *A);
+PETSC_EXTERN PetscErrorCode
+MatCreateSeqBAIJMKL(MPI_Comm,PetscInt,PetscInt,PetscInt,PetscInt,const
+PetscInt[],Mat*); PETSC_EXTERN PetscErrorCode
+MatCreateMPIAIJMKL(MPI_Comm,PetscInt,PetscInt,PetscInt,PetscInt,PetscIn
+t,const PetscInt[],PetscInt,const PetscInt[],Mat*);
#endif
PETSC_EXTERN PetscErrorCode MatCreateSeqSELL(MPI_Comm,PetscInt,PetscInt,PetscInt,const PetscInt[],Mat*);
Also note: - this routine is available only when PETSc is built with Intel MKL
Satish
On Tue, 26 Mar 2019, Kun Jiao via petsc-users wrote:
> [kjiao at hyi0016 src/lsqr]% make
> [ 50%] Building CXX object lsqr/CMakeFiles/p_lsqr.dir/lsqr.cc.o
> /wgdisk/hy3300/source_code_dev/imaging/kjiao/src/git/src/lsqr/lsqr.cc(318): error: identifier "MatCreateMPIAIJMKL" is undefined
> ierr = MatCreateMPIAIJMKL(comm,m,n,M,N,maxnz,dialens,maxnz,offlens,&A);CHKERRQ(ierr);
> /wgdisk/hy3300/source_code_dev/imaging/kjiao/src/git/src/lsqr/lsqr.cc(578): error: identifier "MatCreateMPIAIJMKL" is undefined
> compilation aborted for
> (code 2)
> Thanks.
> From: Mark Adams <mfadams at lbl.gov>
> Sent: Tuesday, March 26, 2019 9:22 AM
> Cc: petsc-users at mcs.anl.gov
> Subject: Re: [Ext] Re: [petsc-users] error: identifier
> I assume the whole error message will have the line of code. Please send the whole error message and line of offending code if not included.
> On Tue, Mar 26, 2019 at 10:08 AM Kun Jiao <KJiao at slb.com<mailto:KJiao at slb.com>> wrote:
> It is compiling error, error message is:
> error: identifier "MatCreateMPIAIJMKL" is undefined.
> From: Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>>
> Sent: Tuesday, March 26, 2019 6:48 AM
> To: Kun Jiao <KJiao at slb.com<mailto:KJiao at slb.com>>
> Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
> Subject: [Ext] Re: [petsc-users] error: identifier
> Please send the output of the error (runtime, compile time, link
> time?)
> On Mon, Mar 25, 2019 at 10:50 PM Kun Jiao via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
> Hi Petsc Experts,
> Is MatCreateMPIAIJMKL retired in 3.10.4?
> I got this error with my code which works fine in 3.8.3 version.
> Regards,
> Kun
