[petsc-users] [Ext] Re: error: identifier "MatCreateMPIAIJMKL" is undefined in 3.10.4
Balay, Satish
balay at mcs.anl.gov
Tue Mar 26 10:18:52 CDT 2019
balay at sb /home/balay/petsc (maint=)
$ git grep MatCreateMPIAIJMKL maint-3.8
maint-3.8:src/mat/impls/aij/mpi/aijmkl/mpiaijmkl.c: MatCreateMPIAIJMKL - Creates a sparse parallel matrix whose local
maint-3.8:src/mat/impls/aij/mpi/aijmkl/mpiaijmkl.c:PetscErrorCode MatCreateMPIAIJMKL(MPI_Comm comm,PetscInt m,PetscInt n,PetscInt M,PetscInt N,PetscInt d_nz,const PetscInt d_nnz[],PetscInt o_nz,const PetscInt o_nnz[],Mat *A)
maint-3.8:src/mat/impls/aij/mpi/aijmkl/mpiaijmkl.c:.seealso: MatCreateMPIAIJMKL(), MATSEQAIJMKL, MATMPIAIJMKL
maint-3.8:src/mat/impls/aij/seq/aijmkl/aijmkl.c:.seealso: MatCreate(), MatCreateMPIAIJMKL(), MatSetValues()
maint:src/mat/impls/aij/mpi/aijmkl/mpiaijmkl.c: MatCreateMPIAIJMKL - Creates a sparse parallel matrix whose local
maint:src/mat/impls/aij/mpi/aijmkl/mpiaijmkl.c:PetscErrorCode MatCreateMPIAIJMKL(MPI_Comm comm,PetscInt m,PetscInt n,PetscInt M,PetscInt N,PetscInt d_nz,const PetscInt d_nnz[],PetscInt o_nz,const PetscInt o_nnz[],Mat *A)
maint:src/mat/impls/aij/mpi/aijmkl/mpiaijmkl.c:.seealso: MatCreateMPIAIJMKL(), MATSEQAIJMKL, MATMPIAIJMKL
maint:src/mat/impls/aij/seq/aijmkl/aijmkl.c:.seealso: MatCreate(), MatCreateMPIAIJMKL(), MatSetValues()
MatCreateMPIAIJMKL() exists in both petsc-3.8 and petsc-3.10. However
the public interface is missing from both of these versions. So I'm
surprised you don't get the same error with petsc-3.8
Can you try the following change?
diff --git a/include/petscmat.h b/include/petscmat.h
index 1b8ac69377..c66f727994 100644
--- a/include/petscmat.h
+++ b/include/petscmat.h
@@ -223,7 +223,8 @@ typedef enum {DIFFERENT_NONZERO_PATTERN,SUBSET_NONZERO_PATTERN,SAME_NONZERO_PATT
#if defined PETSC_HAVE_MKL_SPARSE
PETSC_EXTERN PetscErrorCode MatCreateBAIJMKL(MPI_Comm,PetscInt,PetscInt,PetscInt,PetscInt,PetscInt,PetscInt,const PetscInt[],PetscInt,const PetscInt[],Mat*);
-PETSC_EXTERN PetscErrorCode MatCreateSeqBAIJMKL(MPI_Comm comm,PetscInt bs,PetscInt m,PetscInt n,PetscInt nz,const PetscInt nnz[],Mat *A);
+PETSC_EXTERN PetscErrorCode MatCreateSeqBAIJMKL(MPI_Comm,PetscInt,PetscInt,PetscInt,PetscInt,const PetscInt[],Mat*);
+PETSC_EXTERN PetscErrorCode MatCreateMPIAIJMKL(MPI_Comm,PetscInt,PetscInt,PetscInt,PetscInt,PetscInt,const PetscInt[],PetscInt,const PetscInt[],Mat*);
#endif
PETSC_EXTERN PetscErrorCode MatCreateSeqSELL(MPI_Comm,PetscInt,PetscInt,PetscInt,const PetscInt[],Mat*);
Also note: - this routine is available only when PETSc is built with Intel MKL
Satish
On Tue, 26 Mar 2019, Kun Jiao via petsc-users wrote:
> [kjiao at hyi0016 src/lsqr]% make
> [ 50%] Building CXX object lsqr/CMakeFiles/p_lsqr.dir/lsqr.cc.o
> /wgdisk/hy3300/source_code_dev/imaging/kjiao/src/git/src/lsqr/lsqr.cc(318): error: identifier "MatCreateMPIAIJMKL" is undefined
> ierr = MatCreateMPIAIJMKL(comm,m,n,M,N,maxnz,dialens,maxnz,offlens,&A);CHKERRQ(ierr);
> /wgdisk/hy3300/source_code_dev/imaging/kjiao/src/git/src/lsqr/lsqr.cc(578): error: identifier "MatCreateMPIAIJMKL" is undefined
> compilation aborted for /wgdisk/hy3300/source_code_dev/imaging/kjiao/src/git/src/lsqr/lsqr.cc (code 2)
> Thanks.
> From: Mark Adams <mfadams at lbl.gov>
> Sent: Tuesday, March 26, 2019 9:22 AM
> To: Kun Jiao <KJiao at slb.com>
> Cc: petsc-users at mcs.anl.gov
> Subject: Re: [Ext] Re: [petsc-users] error: identifier "MatCreateMPIAIJMKL" is undefined in 3.10.4
> I assume the whole error message will have the line of code. Please send the whole error message and line of offending code if not included.
> On Tue, Mar 26, 2019 at 10:08 AM Kun Jiao <KJiao at slb.com<mailto:KJiao at slb.com>> wrote:
> It is compiling error, error message is:
> error: identifier "MatCreateMPIAIJMKL" is undefined.
> From: Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>>
> Sent: Tuesday, March 26, 2019 6:48 AM
> To: Kun Jiao <KJiao at slb.com<mailto:KJiao at slb.com>>
> Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
> Subject: [Ext] Re: [petsc-users] error: identifier "MatCreateMPIAIJMKL" is undefined in 3.10.4
> Please send the output of the error (runtime, compile time, link time?)
> On Mon, Mar 25, 2019 at 10:50 PM Kun Jiao via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
> Hi Petsc Experts,
> Is MatCreateMPIAIJMKL retired in 3.10.4?
> I got this error with my code which works fine in 3.8.3 version.
> Regards,
> Kun
> Schlumberger-Private
