[petsc-users] Bad memory scaling with PETSc 3.10
Myriam Peyrounette
myriam.peyrounette at idris.fr
Tue Mar 26 08:26:54 CDT 2019
I checked with -ksp_view (attached) but no prefix is associated with the
matrix. Some are associated to the KSP and PC, but none to the Mat.
Le 03/26/19 à 11:55, Dave May a écrit :
> On Tue, 26 Mar 2019 at 10:36, Myriam Peyrounette
> <myriam.peyrounette at idris.fr <mailto:myriam.peyrounette at idris.fr>> wrote:
> Oh you were right, the three options are unsused (-matptap_via
> scalable, -inner_offdiag_matmatmult_via scalable and
> -inner_diag_matmatmult_via scalable). Does this mean I am not
> using the associated PtAP functions?
> No - not necessarily. All it means is the options were not parsed.
> If your matrices have an option prefix associated with them (e.g. abc)
> , then you need to provide the option as
> -abc_matptap_via scalable
> If you are not sure if you matrices have a prefix, look at the result
> of -ksp_view (see below for an example)
> Mat Object: 2 MPI processes
> type: mpiaij
> rows=363, cols=363, bs=3
> total: nonzeros=8649, allocated nonzeros=8649
> total number of mallocs used during MatSetValues calls =0
> Mat Object: (B_) 2 MPI processes
> type: mpiaij
> The first matrix has no options prefix, but the second does and it's
> called "B_".
> Myriam
> Le 03/26/19 à 11:10, Dave May a écrit :
>> On Tue, 26 Mar 2019 at 09:52, Myriam Peyrounette via petsc-users
>> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>> How can I be sure they are indeed used? Can I print this
>> information in some log file?
>> Yes. Re-run the job with the command line option
>> -options_left true
>> This will report all options parsed, and importantly, will also
>> indicate if any options were unused.
>> Thanks
>> Dave
>> Thanks in advance
>> Myriam
>> Le 03/25/19 à 18:24, Matthew Knepley a écrit :
>>> On Mon, Mar 25, 2019 at 10:54 AM Myriam Peyrounette via
>>> petsc-users <petsc-users at mcs.anl.gov
>>> Hi,
>>> thanks for the explanations. I tried the last PETSc
>>> version (commit
>>> fbc5705bc518d02a4999f188aad4ccff5f754cbf), which
>>> includes the patch you talked about. But the memory
>>> scaling shows no improvement (see scaling attached),
>>> even when using the "scalable" options :(
>>> I had a look at the PETSc functions
>>> MatPtAPNumeric_MPIAIJ_MPIAIJ and
>>> MatPtAPSymbolic_MPIAIJ_MPIAIJ (especially at the
>>> differences before and after the first "bad" commit),
>>> but I can't find what induced this memory issue.
>>> Are you sure that the option was used? It just looks
>>> suspicious to me that they use exactly the same amount of
>>> memory. It should be different, even if it does not solve
>>> the problem.
>>> Thanks,
>>> Matt
>>> Myriam
>>> Le 03/20/19 à 17:38, Fande Kong a écrit :
>>>> Hi Myriam,
>>>> There are three algorithms in PETSc to do PtAP ( const
>>>> char *algTypes[3] =
>>>> {"scalable","nonscalable","hypre"};), and can be
>>>> specified using the petsc options: -matptap_via xxxx.
>>>> (1) -matptap_via hypre: This call the hypre package to
>>>> do the PtAP trough an all-at-once triple product. In
>>>> our experiences, it is the most memory efficient, but
>>>> could be slow.
>>>> (2) -matptap_via scalable: This involves a row-wise
>>>> algorithm plus an outer product. This will use more
>>>> memory than hypre, but way faster. This used to have a
>>>> bug that could take all your memory, and I have a fix
>>>> at https://bitbucket.org/petsc/petsc/pull-requests/1452/mpiptap-enable-large-scale-simulations/diff.
>>>> When using this option, we may want to have extra
>>>> options such as -inner_offdiag_matmatmult_via
>>>> scalable -inner_diag_matmatmult_via scalable to select
>>>> inner scalable algorithms.
>>>> (3) -matptap_via nonscalable: Suppose to be even
>>>> faster, but use more memory. It does dense matrix
>>>> operations.
>>>> Thanks,
>>>> Fande Kong
>>>> On Wed, Mar 20, 2019 at 10:06 AM Myriam Peyrounette via
>>>> More precisely: something happens when upgrading
>>>> the functions MatPtAPNumeric_MPIAIJ_MPIAIJ and/or
>>>> MatPtAPSymbolic_MPIAIJ_MPIAIJ.
>>>> Unfortunately, there are a lot of differences
>>>> between the old and new versions of these
>>>> functions. I keep investigating but if you have any
>>>> idea, please let me know.
>>>> Best,
>>>> Myriam
>>>> Le 03/20/19 à 13:48, Myriam Peyrounette a écrit :
>>>>> Hi all,
>>>>> I used git bisect to determine when the memory
>>>>> need increased. I found that the first "bad"
>>>>> commit is aa690a28a7284adb519c28cb44eae20a2c131c85.
>>>>> Barry was right, this commit seems to be about an
>>>>> evolution of MatPtAPSymbolic_MPIAIJ_MPIAIJ. You
>>>>> mentioned the option "-matptap_via scalable" but I
>>>>> can't find any information about it. Can you tell
>>>>> me more?
>>>>> Thanks
>>>>> Myriam
>>>>> Le 03/11/19 à 14:40, Mark Adams a écrit :
>>>>>> Is there a difference in memory usage on your
>>>>>> tiny problem? I assume no.
>>>>>> I don't see anything that could come from GAMG
>>>>>> other than the RAP stuff that you have discussed
>>>>>> already.
>>>>>> On Mon, Mar 11, 2019 at 9:32 AM Myriam
>>>>>> Peyrounette <myriam.peyrounette at idris.fr
>>>>>> The code I am using here is the example 42 of
>>>>>> PETSc
>>>>>> (https://www.mcs.anl.gov/petsc/petsc-3.9/src/ksp/ksp/examples/tutorials/ex42.c.html).
>>>>>> Indeed it solves the Stokes equation. I
>>>>>> thought it was a good idea to use an example
>>>>>> you might know (and didn't find any that uses
>>>>>> GAMG functions). I just changed the PCMG
>>>>>> setup so that the memory problem appears. And
>>>>>> it appears when adding PCGAMG.
>>>>>> I don't care about the performance or even
>>>>>> the result rightness here, but only about the
>>>>>> difference in memory use between 3.6 and
>>>>>> 3.10. Do you think finding a more adapted
>>>>>> script would help?
>>>>>> I used the threshold of 0.1 only once, at the
>>>>>> beginning, to test its influence. I used the
>>>>>> default threshold (of 0, I guess) for all the
>>>>>> other runs.
>>>>>> Myriam
>>>>>> Le 03/11/19 à 13:52, Mark Adams a écrit :
>>>>>>> In looking at this larger scale run ...
>>>>>>> * Your eigen estimates are much lower than
>>>>>>> your tiny test problem. But this is Stokes
>>>>>>> apparently and it should not work anyway.
>>>>>>> Maybe you have a small time step that adds a
>>>>>>> lot of mass that brings the eigen estimates
>>>>>>> down. And your min eigenvalue (not used) is
>>>>>>> positive. I would expect negative for Stokes ...
>>>>>>> * You seem to be setting a threshold value
>>>>>>> of 0.1 -- that is very high
>>>>>>> * v3.6 says "using nonzero initial guess"
>>>>>>> but this is not in v3.10. Maybe we just
>>>>>>> stopped printing that.
>>>>>>> * There were some changes to coasening
>>>>>>> parameters in going from v3.6 but it does
>>>>>>> not look like your problem was effected.
>>>>>>> (The coarsening algo is non-deterministic by
>>>>>>> default and you can see small difference on
>>>>>>> different runs)
>>>>>>> * We may have also added a "noisy" RHS for
>>>>>>> eigen estimates by default from v3.6.
>>>>>>> * And for non-symetric problems you can try
>>>>>>> -pc_gamg_agg_nsmooths 0, but again GAMG is
>>>>>>> not built for Stokes anyway.
>>>>>>> On Tue, Mar 5, 2019 at 11:53 AM Myriam
>>>>>>> I used PCView to display the size of the
>>>>>>> linear system in each level of the MG.
>>>>>>> You'll find the outputs attached to this
>>>>>>> mail (zip file) for both the default
>>>>>>> threshold value and a value of 0.1, and
>>>>>>> for both 3.6 and 3.10 PETSc versions.
>>>>>>> For convenience, I summarized the
>>>>>>> information in a graph, also attached
>>>>>>> (png file).
>>>>>>> As you can see, there are slight
>>>>>>> differences between the two versions but
>>>>>>> none is critical, in my opinion. Do you
>>>>>>> see anything suspicious in the outputs?
>>>>>>> + I can't find the default threshold
>>>>>>> value. Do you know where I can find it?
>>>>>>> Thanks for the follow-up
>>>>>>> Myriam
>>>>>>> Le 03/05/19 à 14:06, Matthew Knepley a
>>>>>>> écrit :
>>>>>>>> On Tue, Mar 5, 2019 at 7:14 AM Myriam
>>>>>>>> Peyrounette
>>>>>>>> wrote:
>>>>>>>> Hi Matt,
>>>>>>>> I plotted the memory scalings using
>>>>>>>> different threshold values. The two
>>>>>>>> scalings are slightly translated
>>>>>>>> (from -22 to -88 mB) but this gain
>>>>>>>> is neglectable. The 3.6-scaling
>>>>>>>> keeps being robust while the
>>>>>>>> 3.10-scaling deteriorates.
>>>>>>>> Do you have any other suggestion?
>>>>>>>> Mark, what is the option she can give
>>>>>>>> to output all the GAMG data?
>>>>>>>> Also, run using -ksp_view. GAMG will
>>>>>>>> report all the sizes of its grids, so
>>>>>>>> it should be easy to see
>>>>>>>> if the coarse grid sizes are
>>>>>>>> increasing, and also what the effect of
>>>>>>>> the threshold value is.
>>>>>>>> Thanks,
>>>>>>>> Matt
>>>>>>>> Thanks
>>>>>>>> Myriam
>>>>>>>> Le 03/02/19 à 02:27, Matthew
>>>>>>>> Knepley a écrit :
>>>>>>>>> On Fri, Mar 1, 2019 at 10:53 AM
>>>>>>>>> wrote:
>>>>>>>>> Hi,
>>>>>>>>> I used to run my code with
>>>>>>>>> PETSc 3.6. Since I upgraded
>>>>>>>>> the PETSc version
>>>>>>>>> to 3.10, this code has a bad
>>>>>>>>> memory scaling.
>>>>>>>>> To report this issue, I took
>>>>>>>>> the PETSc script ex42.c and
>>>>>>>>> slightly
>>>>>>>>> modified it so that the KSP
>>>>>>>>> and PC configurations are the
>>>>>>>>> same as in my
>>>>>>>>> code. In particular, I use a
>>>>>>>>> "personnalised" multi-grid
>>>>>>>>> method. The
>>>>>>>>> modifications are indicated by
>>>>>>>>> the keyword "TopBridge" in the
>>>>>>>>> attached
>>>>>>>>> scripts.
>>>>>>>>> To plot the memory (weak)
>>>>>>>>> scaling, I ran four
>>>>>>>>> calculations for each
>>>>>>>>> script with increasing problem
>>>>>>>>> sizes and computations cores:
>>>>>>>>> 1. 100,000 elts on 4 cores
>>>>>>>>> 2. 1 million elts on 40 cores
>>>>>>>>> 3. 10 millions elts on 400 cores
>>>>>>>>> 4. 100 millions elts on 4,000
>>>>>>>>> cores
>>>>>>>>> The resulting graph is also
>>>>>>>>> attached. The scaling using
>>>>>>>>> PETSc 3.10
>>>>>>>>> clearly deteriorates for large
>>>>>>>>> cases, while the one using
>>>>>>>>> PETSc 3.6 is
>>>>>>>>> robust.
>>>>>>>>> After a few tests, I found
>>>>>>>>> that the scaling is mostly
>>>>>>>>> sensitive to the
>>>>>>>>> use of the AMG method for the
>>>>>>>>> coarse grid (line 1780 in
>>>>>>>>> main_ex42_petsc36.cc). In
>>>>>>>>> particular, the performance
>>>>>>>>> strongly
>>>>>>>>> deteriorates when commenting
>>>>>>>>> lines 1777 to 1790 (in
>>>>>>>>> Do you have any idea of what
>>>>>>>>> changed between version 3.6
>>>>>>>>> and version
>>>>>>>>> 3.10 that may imply such
>>>>>>>>> degradation?
>>>>>>>>> I believe the default values for
>>>>>>>>> PCGAMG changed between versions.
>>>>>>>>> It sounds like the coarsening rate
>>>>>>>>> is not great enough, so that these
>>>>>>>>> grids are too large. This can be
>>>>>>>>> set using:
>>>>>>>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGAMGSetThreshold.html
>>>>>>>>> There is some explanation of this
>>>>>>>>> effect on that page. Let us know
>>>>>>>>> if setting this does not correct
>>>>>>>>> the situation.
>>>>>>>>> Thanks,
>>>>>>>>> Matt
>>>>>>>>> Let me know if you need
>>>>>>>>> further information.
>>>>>>>>> Best,
>>>>>>>>> Myriam Peyrounette
>>>>>>>>> Myriam Peyrounette
>>>>>>>>> CNRS/IDRIS - HLST
>>>>>>>>> What most experimenters take for
>>>>>>>>> granted before they begin their
>>>>>>>>> experiments is infinitely more
>>>>>>>>> interesting than any results to
>>>>>>>>> which their experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>> <http://www.cse.buffalo.edu/%7Eknepley/>
>>>>>>>> Myriam Peyrounette
>>>>>>>> CNRS/IDRIS - HLST
>>>>>>>> interesting than any results to which
>>>>>>>> -- Norbert Wiener
>>>>>>> Myriam Peyrounette
>>>>>>> CNRS/IDRIS - HLST
>>>>>> Myriam Peyrounette
>>>>>> CNRS/IDRIS - HLST
>>>>> Myriam Peyrounette
>>>>> CNRS/IDRIS - HLST
>>>> Myriam Peyrounette
>>>> CNRS/IDRIS - HLST
>>> Myriam Peyrounette
>>> CNRS/IDRIS - HLST
>>> What most experimenters take for granted before they begin
>>> their experiments is infinitely more interesting than any
>>> results to which their experiments lead.
>>> -- Norbert Wiener
>> Myriam Peyrounette
>> CNRS/IDRIS - HLST
> Myriam Peyrounette
> CNRS/IDRIS - HLST
Myriam Peyrounette
CNRS/IDRIS - HLST
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190326/26010c5f/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190326/26010c5f/attachment-0001.bin>
Type: application/pkcs7-signature
Desc: Signature cryptographique S/MIME
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190326/26010c5f/attachment-0001.p7s>
