[petsc-users] Bad memory scaling with PETSc 3.10
    Dave May
    dave.mayhem23 at gmail.com
    Tue Mar 26 05:55:40 CDT 2019
On Tue, 26 Mar 2019 at 10:36, Myriam Peyrounette <
myriam.peyrounette at idris.fr> wrote:
> Oh you were right, the three options are unsused (-matptap_via scalable,
> -inner_offdiag_matmatmult_via scalable and -inner_diag_matmatmult_via
> scalable). Does this mean I am not using the associated PtAP functions?
No - not necessarily. All it means is the options were not parsed.
If your matrices have an option prefix associated with them (e.g. abc) ,
then you need to provide the option as
  -abc_matptap_via scalable
If you are not sure if you matrices have a prefix, look at the result of
-ksp_view (see below for an example)
  Mat Object: 2 MPI processes
    type: mpiaij
    rows=363, cols=363, bs=3
    total: nonzeros=8649, allocated nonzeros=8649
    total number of mallocs used during MatSetValues calls =0
  Mat Object: (B_) 2 MPI processes
    type: mpiaij
The first matrix has no options prefix, but the second does and it's called
"B_".
> Myriam
> Le 03/26/19 à 11:10, Dave May a écrit :
> On Tue, 26 Mar 2019 at 09:52, Myriam Peyrounette via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> How can I be sure they are indeed used? Can I print this information in
>> some log file?
> Yes. Re-run the job with the command line option
> -options_left true
> This will report all options parsed, and importantly, will also indicate
> if any options were unused.
> Thanks
> Dave
> Thanks in advance
>> Myriam
>> Le 03/25/19 à 18:24, Matthew Knepley a écrit :
>> On Mon, Mar 25, 2019 at 10:54 AM Myriam Peyrounette via petsc-users <
>>> Hi,
>>> thanks for the explanations. I tried the last PETSc version (commit
>>> fbc5705bc518d02a4999f188aad4ccff5f754cbf), which includes the patch you
>>> talked about. But the memory scaling shows no improvement (see scaling
>>> attached), even when using the "scalable" options :(
>>> I had a look at the PETSc functions MatPtAPNumeric_MPIAIJ_MPIAIJ and
>>> MatPtAPSymbolic_MPIAIJ_MPIAIJ (especially at the differences before and
>>> after the first "bad" commit), but I can't find what induced this memory
>>> issue.
>> Are you sure that the option was used? It just looks suspicious to me
>> that they use exactly the same amount of memory. It should be different,
>> even if it does not solve the problem.
>>    Thanks,
>>      Matt
>>> Myriam
>>> Le 03/20/19 à 17:38, Fande Kong a écrit :
>>> Hi Myriam,
>>> There are three algorithms in PETSc to do PtAP ( const char
>>> *algTypes[3] = {"scalable","nonscalable","hypre"};), and can be specified
>>> using the petsc options: -matptap_via xxxx.
>>> (1) -matptap_via hypre: This call the hypre package to do the PtAP
>>> trough an all-at-once triple product. In our experiences, it is the most
>>> memory efficient, but could be slow.
>>> (2)  -matptap_via scalable: This involves a row-wise algorithm plus an
>>> outer product.  This will use more memory than hypre, but way faster. This
>>> used to have a bug that could take all your memory, and I have a fix at
>>> https://bitbucket.org/petsc/petsc/pull-requests/1452/mpiptap-enable-large-scale-simulations/diff.
>>> When using this option, we may want to have extra options such as
>>>  -inner_offdiag_matmatmult_via scalable -inner_diag_matmatmult_via
>>> scalable  to select inner scalable algorithms.
>>> (3)  -matptap_via nonscalable:  Suppose to be even faster, but use more
>>> memory. It does dense matrix operations.
>>> Thanks,
>>> Fande Kong
>>> On Wed, Mar 20, 2019 at 10:06 AM Myriam Peyrounette via petsc-users <
>>>> More precisely: something happens when upgrading the functions
>>>> MatPtAPNumeric_MPIAIJ_MPIAIJ and/or MatPtAPSymbolic_MPIAIJ_MPIAIJ.
>>>> Unfortunately, there are a lot of differences between the old and new
>>>> versions of these functions. I keep investigating but if you have any idea,
>>>> please let me know.
>>>> Best,
>>>> Myriam
>>>> Le 03/20/19 à 13:48, Myriam Peyrounette a écrit :
>>>> Hi all,
>>>> I used git bisect to determine when the memory need increased. I found
>>>> that the first "bad" commit is   aa690a28a7284adb519c28cb44eae20a2c131c85.
>>>> Barry was right, this commit seems to be about an evolution of MatPtAPSymbolic_MPIAIJ_MPIAIJ.
>>>> You mentioned the option "-matptap_via scalable" but I can't find any
>>>> information about it. Can you tell me more?
>>>> Thanks
>>>> Myriam
>>>> Le 03/11/19 à 14:40, Mark Adams a écrit :
>>>> Is there a difference in memory usage on your tiny problem? I assume
>>>> no.
>>>> I don't see anything that could come from GAMG other than the RAP stuff
>>>> that you have discussed already.
>>>> On Mon, Mar 11, 2019 at 9:32 AM Myriam Peyrounette <
>>>>> The code I am using here is the example 42 of PETSc (
>>>>> https://www.mcs.anl.gov/petsc/petsc-3.9/src/ksp/ksp/examples/tutorials/ex42.c.html).
>>>>> Indeed it solves the Stokes equation. I thought it was a good idea to use
>>>>> an example you might know (and didn't find any that uses GAMG functions). I
>>>>> just changed the PCMG setup so that the memory problem appears. And it
>>>>> appears when adding PCGAMG.
>>>>> I don't care about the performance or even the result rightness here,
>>>>> but only about the difference in memory use between 3.6 and 3.10. Do you
>>>>> think finding a more adapted script would help?
>>>>> I used the threshold of 0.1 only once, at the beginning, to test its
>>>>> influence. I used the default threshold (of 0, I guess) for all the other
>>>>> runs.
>>>>> Myriam
>>>>> Le 03/11/19 à 13:52, Mark Adams a écrit :
>>>>> In looking at this larger scale run ...
>>>>> * Your eigen estimates are much lower than your tiny test problem.
>>>>> But this is Stokes apparently and it should not work anyway. Maybe you have
>>>>> a small time step that adds a lot of mass that brings the eigen estimates
>>>>> down. And your min eigenvalue (not used) is positive. I would expect
>>>>> negative for Stokes ...
>>>>> * You seem to be setting a threshold value of 0.1 -- that is very high
>>>>> * v3.6 says "using nonzero initial guess" but this is not in v3.10.
>>>>> Maybe we just stopped printing that.
>>>>> * There were some changes to coasening parameters in going from v3.6
>>>>> but it does not look like your problem was effected. (The coarsening algo
>>>>> is non-deterministic by default and you can see small difference on
>>>>> different runs)
>>>>> * We may have also added a "noisy" RHS for eigen estimates by default
>>>>> from v3.6.
>>>>> * And for non-symetric problems you can try -pc_gamg_agg_nsmooths 0,
>>>>> but again GAMG is not built for Stokes anyway.
>>>>> On Tue, Mar 5, 2019 at 11:53 AM Myriam Peyrounette <
>>>>>> I used PCView to display the size of the linear system in each level
>>>>>> of the MG. You'll find the outputs attached to this mail (zip file) for
>>>>>> both the default threshold value and a value of 0.1, and for both 3.6 and
>>>>>> 3.10 PETSc versions.
>>>>>> For convenience, I summarized the information in a graph, also
>>>>>> attached (png file).
>>>>>> As you can see, there are slight differences between the two versions
>>>>>> but none is critical, in my opinion. Do you see anything suspicious in the
>>>>>> outputs?
>>>>>> + I can't find the default threshold value. Do you know where I can
>>>>>> find it?
>>>>>> Thanks for the follow-up
>>>>>> Myriam
>>>>>> Le 03/05/19 à 14:06, Matthew Knepley a écrit :
>>>>>> On Tue, Mar 5, 2019 at 7:14 AM Myriam Peyrounette <
>>>>>>> Hi Matt,
>>>>>>> I plotted the memory scalings using different threshold values. The
>>>>>>> two scalings are slightly translated (from -22 to -88 mB) but this gain is
>>>>>>> neglectable. The 3.6-scaling keeps being robust while the 3.10-scaling
>>>>>>> deteriorates.
>>>>>>> Do you have any other suggestion?
>>>>>> Mark, what is the option she can give to output all the GAMG data?
>>>>>> Also, run using -ksp_view. GAMG will report all the sizes of its
>>>>>> grids, so it should be easy to see
>>>>>> if the coarse grid sizes are increasing, and also what the effect of
>>>>>> the threshold value is.
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> Thanks
>>>>>>> Myriam
>>>>>>> Le 03/02/19 à 02:27, Matthew Knepley a écrit :
>>>>>>> On Fri, Mar 1, 2019 at 10:53 AM Myriam Peyrounette via petsc-users <
>>>>>>>> Hi,
>>>>>>>> I used to run my code with PETSc 3.6. Since I upgraded the PETSc
>>>>>>>> version
>>>>>>>> to 3.10, this code has a bad memory scaling.
>>>>>>>> To report this issue, I took the PETSc script ex42.c and slightly
>>>>>>>> modified it so that the KSP and PC configurations are the same as
>>>>>>>> in my
>>>>>>>> code. In particular, I use a "personnalised" multi-grid method. The
>>>>>>>> modifications are indicated by the keyword "TopBridge" in the
>>>>>>>> attached
>>>>>>>> scripts.
>>>>>>>> To plot the memory (weak) scaling, I ran four calculations for each
>>>>>>>> script with increasing problem sizes and computations cores:
>>>>>>>> 1. 100,000 elts on 4 cores
>>>>>>>> 2. 1 million elts on 40 cores
>>>>>>>> 3. 10 millions elts on 400 cores
>>>>>>>> 4. 100 millions elts on 4,000 cores
>>>>>>>> The resulting graph is also attached. The scaling using PETSc 3.10
>>>>>>>> clearly deteriorates for large cases, while the one using PETSc 3.6
>>>>>>>> is
>>>>>>>> robust.
>>>>>>>> After a few tests, I found that the scaling is mostly sensitive to
>>>>>>>> the
>>>>>>>> use of the AMG method for the coarse grid (line 1780 in
>>>>>>>> main_ex42_petsc36.cc). In particular, the performance strongly
>>>>>>>> deteriorates when commenting lines 1777 to 1790 (in
>>>>>>>> Do you have any idea of what changed between version 3.6 and version
>>>>>>>> 3.10 that may imply such degradation?
>>>>>>> I believe the default values for PCGAMG changed between versions. It
>>>>>>> sounds like the coarsening rate
>>>>>>> is not great enough, so that these grids are too large. This can be
>>>>>>> set using:
>>>>>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGAMGSetThreshold.html
>>>>>>> There is some explanation of this effect on that page. Let us know
>>>>>>> if setting this does not correct the situation.
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>> Let me know if you need further information.
>>>>>>>> Best,
>>>>>>>> Myriam Peyrounette
>>>>>>>> Myriam Peyrounette
>>>>>>>> CNRS/IDRIS - HLST
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>> <http://www.cse.buffalo.edu/%7Eknepley/>
>>>>>>> Myriam Peyrounette
>>>>>>> CNRS/IDRIS - HLST
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> Myriam Peyrounette
>>>>>> CNRS/IDRIS - HLST
>>>>> Myriam Peyrounette
>>>>> CNRS/IDRIS - HLST
>>>> Myriam Peyrounette
>>>> CNRS/IDRIS - HLST
>>>> Myriam Peyrounette
>>>> CNRS/IDRIS - HLST
>>> Myriam Peyrounette
>>> CNRS/IDRIS - HLST
>> experiments lead.
>> -- Norbert Wiener
>> Myriam Peyrounette
>> CNRS/IDRIS - HLST
> Myriam Peyrounette
> CNRS/IDRIS - HLST
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190326/06673da7/attachment-0001.html>
