[petsc-users] Bad memory scaling with PETSc 3.10
Myriam Peyrounette
myriam.peyrounette at idris.fr
Mon Mar 25 09:54:29 CDT 2019
thanks for the explanations. I tried the last PETSc version (commit
fbc5705bc518d02a4999f188aad4ccff5f754cbf), which includes the patch you
talked about. But the memory scaling shows no improvement (see scaling
attached), even when using the "scalable" options :(
I had a look at the PETSc functions MatPtAPNumeric_MPIAIJ_MPIAIJ and
MatPtAPSymbolic_MPIAIJ_MPIAIJ (especially at the differences before and
after the first "bad" commit), but I can't find what induced this memory
issue.
Myriam
Le 03/20/19 à 17:38, Fande Kong a écrit :
> Hi Myriam,
> There are three algorithms in PETSc to do PtAP ( const char
> *algTypes[3] = {"scalable","nonscalable","hypre"};), and can be
> specified using the petsc options: -matptap_via xxxx.
> (1) -matptap_via hypre: This call the hypre package to do the PtAP
> trough an all-at-once triple product. In our experiences, it is the
> most memory efficient, but could be slow.
> (2) -matptap_via scalable: This involves a row-wise algorithm plus an
> outer product. This will use more memory than hypre, but way faster.
> This used to have a bug that could take all your memory, and I have a
> fix
> at https://bitbucket.org/petsc/petsc/pull-requests/1452/mpiptap-enable-large-scale-simulations/diff.
> When using this option, we may want to have extra options such as
> -inner_offdiag_matmatmult_via scalable -inner_diag_matmatmult_via
> scalable to select inner scalable algorithms.
> (3) -matptap_via nonscalable: Suppose to be even faster, but use
> more memory. It does dense matrix operations.
> Thanks,
> Fande Kong
> On Wed, Mar 20, 2019 at 10:06 AM Myriam Peyrounette via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> More precisely: something happens when upgrading the functions
> MatPtAPNumeric_MPIAIJ_MPIAIJ and/or MatPtAPSymbolic_MPIAIJ_MPIAIJ.
> Unfortunately, there are a lot of differences between the old and
> new versions of these functions. I keep investigating but if you
> have any idea, please let me know.
> Best,
> Myriam
> Le 03/20/19 à 13:48, Myriam Peyrounette a écrit :
>> Hi all,
>> I used git bisect to determine when the memory need increased. I
>> found that the first "bad" commit is
>> aa690a28a7284adb519c28cb44eae20a2c131c85.
>> Barry was right, this commit seems to be about an evolution of
>> MatPtAPSymbolic_MPIAIJ_MPIAIJ. You mentioned the option
>> "-matptap_via scalable" but I can't find any information about
>> it. Can you tell me more?
>> Thanks
>> Myriam
>> Le 03/11/19 à 14:40, Mark Adams a écrit :
>>> Is there a difference in memory usage on your tiny problem? I
>>> assume no.
>>> I don't see anything that could come from GAMG other than the
>>> RAP stuff that you have discussed already.
>>> On Mon, Mar 11, 2019 at 9:32 AM Myriam Peyrounette
>>> <myriam.peyrounette at idris.fr
>>> <mailto:myriam.peyrounette at idris.fr>> wrote:
>>> The code I am using here is the example 42 of PETSc
>>> (https://www.mcs.anl.gov/petsc/petsc-3.9/src/ksp/ksp/examples/tutorials/ex42.c.html).
>>> Indeed it solves the Stokes equation. I thought it was a
>>> good idea to use an example you might know (and didn't find
>>> any that uses GAMG functions). I just changed the PCMG setup
>>> so that the memory problem appears. And it appears when
>>> adding PCGAMG.
>>> I don't care about the performance or even the result
>>> rightness here, but only about the difference in memory use
>>> between 3.6 and 3.10. Do you think finding a more adapted
>>> script would help?
>>> I used the threshold of 0.1 only once, at the beginning, to
>>> test its influence. I used the default threshold (of 0, I
>>> guess) for all the other runs.
>>> Myriam
>>> Le 03/11/19 à 13:52, Mark Adams a écrit :
>>>> In looking at this larger scale run ...
>>>> * Your eigen estimates are much lower than your tiny test
>>>> problem. But this is Stokes apparently and it should not
>>>> work anyway. Maybe you have a small time step that adds a
>>>> lot of mass that brings the eigen estimates down. And your
>>>> min eigenvalue (not used) is positive. I would expect
>>>> negative for Stokes ...
>>>> * You seem to be setting a threshold value of 0.1 -- that
>>>> is very high
>>>> * v3.6 says "using nonzero initial guess" but this is not
>>>> in v3.10. Maybe we just stopped printing that.
>>>> * There were some changes to coasening parameters in going
>>>> from v3.6 but it does not look like your problem was
>>>> effected. (The coarsening algo is non-deterministic by
>>>> default and you can see small difference on different runs)
>>>> * We may have also added a "noisy" RHS for eigen estimates
>>>> by default from v3.6.
>>>> * And for non-symetric problems you can try
>>>> -pc_gamg_agg_nsmooths 0, but again GAMG is not built for
>>>> Stokes anyway.
>>>> On Tue, Mar 5, 2019 at 11:53 AM Myriam Peyrounette
>>>> I used PCView to display the size of the linear system
>>>> in each level of the MG. You'll find the outputs
>>>> attached to this mail (zip file) for both the default
>>>> threshold value and a value of 0.1, and for both 3.6
>>>> and 3.10 PETSc versions.
>>>> For convenience, I summarized the information in a
>>>> graph, also attached (png file).
>>>> As you can see, there are slight differences between
>>>> the two versions but none is critical, in my opinion.
>>>> Do you see anything suspicious in the outputs?
>>>> + I can't find the default threshold value. Do you know
>>>> where I can find it?
>>>> Thanks for the follow-up
>>>> Myriam
>>>> Le 03/05/19 à 14:06, Matthew Knepley a écrit :
>>>>> On Tue, Mar 5, 2019 at 7:14 AM Myriam Peyrounette
>>>>> Hi Matt,
>>>>> I plotted the memory scalings using different
>>>>> threshold values. The two scalings are slightly
>>>>> translated (from -22 to -88 mB) but this gain is
>>>>> neglectable. The 3.6-scaling keeps being robust
>>>>> while the 3.10-scaling deteriorates.
>>>>> Do you have any other suggestion?
>>>>> Mark, what is the option she can give to output all
>>>>> the GAMG data?
>>>>> Also, run using -ksp_view. GAMG will report all the
>>>>> sizes of its grids, so it should be easy to see
>>>>> if the coarse grid sizes are increasing, and also what
>>>>> the effect of the threshold value is.
>>>>> Thanks,
>>>>> Matt
>>>>> Thanks
>>>>> Myriam
>>>>> Le 03/02/19 à 02:27, Matthew Knepley a écrit :
>>>>>> On Fri, Mar 1, 2019 at 10:53 AM Myriam
>>>>>> Hi,
>>>>>> I used to run my code with PETSc 3.6. Since I
>>>>>> upgraded the PETSc version
>>>>>> to 3.10, this code has a bad memory scaling.
>>>>>> To report this issue, I took the PETSc script
>>>>>> ex42.c and slightly
>>>>>> modified it so that the KSP and PC
>>>>>> configurations are the same as in my
>>>>>> code. In particular, I use a "personnalised"
>>>>>> multi-grid method. The
>>>>>> modifications are indicated by the keyword
>>>>>> "TopBridge" in the attached
>>>>>> scripts.
>>>>>> To plot the memory (weak) scaling, I ran four
>>>>>> calculations for each
>>>>>> script with increasing problem sizes and
>>>>>> computations cores:
>>>>>> 1. 100,000 elts on 4 cores
>>>>>> 2. 1 million elts on 40 cores
>>>>>> 3. 10 millions elts on 400 cores
>>>>>> 4. 100 millions elts on 4,000 cores
>>>>>> The resulting graph is also attached. The
>>>>>> scaling using PETSc 3.10
>>>>>> clearly deteriorates for large cases, while
>>>>>> the one using PETSc 3.6 is
>>>>>> robust.
>>>>>> After a few tests, I found that the scaling
>>>>>> is mostly sensitive to the
>>>>>> use of the AMG method for the coarse grid
>>>>>> (line 1780 in
>>>>>> main_ex42_petsc36.cc). In particular, the
>>>>>> performance strongly
>>>>>> deteriorates when commenting lines 1777 to
>>>>>> 1790 (in main_ex42_petsc36.cc).
>>>>>> Do you have any idea of what changed between
>>>>>> version 3.6 and version
>>>>>> 3.10 that may imply such degradation?
>>>>>> I believe the default values for PCGAMG changed
>>>>>> between versions. It sounds like the coarsening rate
>>>>>> is not great enough, so that these grids are too
>>>>>> large. This can be set using:
>>>>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGAMGSetThreshold.html
>>>>>> There is some explanation of this effect on that
>>>>>> page. Let us know if setting this does not
>>>>>> correct the situation.
>>>>>> Thanks,
>>>>>> Matt
>>>>>> Let me know if you need further information.
>>>>>> Best,
>>>>>> Myriam Peyrounette
>>>>>> Myriam Peyrounette
>>>>>> CNRS/IDRIS - HLST
>>>>>> What most experimenters take for granted before
>>>>>> they begin their experiments is infinitely more
>>>>>> interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/%7Eknepley/>
>>>>> Myriam Peyrounette
>>>>> CNRS/IDRIS - HLST
>>>>> What most experimenters take for granted before they
>>>>> begin their experiments is infinitely more interesting
>>>>> than any results to which their experiments lead.
>>>>> -- Norbert Wiener
>>>> Myriam Peyrounette
>>>> CNRS/IDRIS - HLST
>>> Myriam Peyrounette
>>> CNRS/IDRIS - HLST
>> Myriam Peyrounette
>> CNRS/IDRIS - HLST
> Myriam Peyrounette
> CNRS/IDRIS - HLST
Myriam Peyrounette
CNRS/IDRIS - HLST
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190325/2444f570/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190325/2444f570/attachment-0001.png>
Type: application/pkcs7-signature
Desc: Signature cryptographique S/MIME
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190325/2444f570/attachment-0001.p7s>
