[petsc-users] Bad memory scaling with PETSc 3.10
Fande Kong fdkong.jd at gmail.com
Wed Mar 20 11:38:58 CDT 2019
Hi Myriam,
There are three algorithms in PETSc to do PtAP ( const char
*algTypes[3] = {"scalable","nonscalable","hypre"};), and can be specified
using the petsc options: -matptap_via xxxx.
(1) -matptap_via hypre: This call the hypre package to do the PtAP trough
an all-at-once triple product. In our experiences, it is the most memory
efficient, but could be slow.
(2)  -matptap_via scalable: This involves a row-wise algorithm plus an
outer product.  This will use more memory than hypre, but way faster. This
used to have a bug that could take all your memory, and I have a fix at
https://bitbucket.org/petsc/petsc/pull-requests/1452/mpiptap-enable-large-scale-simulations/diff.
When using this option, we may want to have extra options such as
 -inner_offdiag_matmatmult_via scalable -inner_diag_matmatmult_via
scalable  to select inner scalable algorithms.
(3)  -matptap_via nonscalable:  Suppose to be even faster, but use more
memory. It does dense matrix operations.
Fande Kong
On Wed, Mar 20, 2019 at 10:06 AM Myriam Peyrounette via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> More precisely: something happens when upgrading the functions
> MatPtAPNumeric_MPIAIJ_MPIAIJ and/or MatPtAPSymbolic_MPIAIJ_MPIAIJ.
> Unfortunately, there are a lot of differences between the old and new
> versions of these functions. I keep investigating but if you have any idea,
> please let me know.
> Best,
> Myriam
> Le 03/20/19 à 13:48, Myriam Peyrounette a écrit :
> Hi all,
> I used git bisect to determine when the memory need increased. I found
> that the first "bad" commit is   aa690a28a7284adb519c28cb44eae20a2c131c85.
> Barry was right, this commit seems to be about an evolution of MatPtAPSymbolic_MPIAIJ_MPIAIJ.
> You mentioned the option "-matptap_via scalable" but I can't find any
> information about it. Can you tell me more?
> Thanks
> Myriam
> Le 03/11/19 à 14:40, Mark Adams a écrit :
> Is there a difference in memory usage on your tiny problem? I assume no.
> I don't see anything that could come from GAMG other than the RAP stuff
> that you have discussed already.
> On Mon, Mar 11, 2019 at 9:32 AM Myriam Peyrounette <
> myriam.peyrounette at idris.fr> wrote:
>> The code I am using here is the example 42 of PETSc (
>> https://www.mcs.anl.gov/petsc/petsc-3.9/src/ksp/ksp/examples/tutorials/ex42.c.html).
>> Indeed it solves the Stokes equation. I thought it was a good idea to use
>> an example you might know (and didn't find any that uses GAMG functions). I
>> just changed the PCMG setup so that the memory problem appears. And it
>> appears when adding PCGAMG.
>> I don't care about the performance or even the result rightness here, but
>> only about the difference in memory use between 3.6 and 3.10. Do you think
>> finding a more adapted script would help?
>> I used the threshold of 0.1 only once, at the beginning, to test its
>> influence. I used the default threshold (of 0, I guess) for all the other
>> runs.
>> Myriam
>> Le 03/11/19 à 13:52, Mark Adams a écrit :
>> In looking at this larger scale run ...
>> * Your eigen estimates are much lower than your tiny test problem.  But
>> this is Stokes apparently and it should not work anyway. Maybe you have a
>> small time step that adds a lot of mass that brings the eigen estimates
>> down. And your min eigenvalue (not used) is positive. I would expect
>> negative for Stokes ...
>> * You seem to be setting a threshold value of 0.1 -- that is very high
>> * v3.6 says "using nonzero initial guess" but this is not in v3.10. Maybe
>> we just stopped printing that.
>> * There were some changes to coasening parameters in going from v3.6 but
>> it does not look like your problem was effected. (The coarsening algo is
>> non-deterministic by default and you can see small difference on different
>> runs)
>> * We may have also added a "noisy" RHS for eigen estimates by default
>> from v3.6.
>> * And for non-symetric problems you can try -pc_gamg_agg_nsmooths 0, but
>> again GAMG is not built for Stokes anyway.
>> On Tue, Mar 5, 2019 at 11:53 AM Myriam Peyrounette <
>>> I used PCView to display the size of the linear system in each level of
>>> the MG. You'll find the outputs attached to this mail (zip file) for both
>>> the default threshold value and a value of 0.1, and for both 3.6 and 3.10
>>> PETSc versions.
>>> For convenience, I summarized the information in a graph, also attached
>>> (png file).
>>> As you can see, there are slight differences between the two versions
>>> but none is critical, in my opinion. Do you see anything suspicious in the
>>> outputs?
>>> + I can't find the default threshold value. Do you know where I can find
>>> it?
>>> Thanks for the follow-up
>>> Myriam
>>> Le 03/05/19 à 14:06, Matthew Knepley a écrit :
>>> On Tue, Mar 5, 2019 at 7:14 AM Myriam Peyrounette <
>>>> Hi Matt,
>>>> I plotted the memory scalings using different threshold values. The two
>>>> scalings are slightly translated (from -22 to -88 mB) but this gain is
>>>> neglectable. The 3.6-scaling keeps being robust while the 3.10-scaling
>>>> deteriorates.
>>>> Do you have any other suggestion?
>>> Mark, what is the option she can give to output all the GAMG data?
>>> Also, run using -ksp_view. GAMG will report all the sizes of its grids,
>>> so it should be easy to see
>>> if the coarse grid sizes are increasing, and also what the effect of the
>>> threshold value is.
>>>   Thanks,
>>>      Matt
>>>> Thanks
>>>> Myriam
>>>> Le 03/02/19 à 02:27, Matthew Knepley a écrit :
>>>> On Fri, Mar 1, 2019 at 10:53 AM Myriam Peyrounette via petsc-users <
>>>>> Hi,
>>>>> I used to run my code with PETSc 3.6. Since I upgraded the PETSc
>>>>> version
>>>>> to 3.10, this code has a bad memory scaling.
>>>>> To report this issue, I took the PETSc script ex42.c and slightly
>>>>> modified it so that the KSP and PC configurations are the same as in my
>>>>> code. In particular, I use a "personnalised" multi-grid method. The
>>>>> modifications are indicated by the keyword "TopBridge" in the attached
>>>>> scripts.
>>>>> To plot the memory (weak) scaling, I ran four calculations for each
>>>>> script with increasing problem sizes and computations cores:
>>>>> 1. 100,000 elts on 4 cores
>>>>> 2. 1 million elts on 40 cores
>>>>> 3. 10 millions elts on 400 cores
>>>>> 4. 100 millions elts on 4,000 cores
>>>>> The resulting graph is also attached. The scaling using PETSc 3.10
>>>>> clearly deteriorates for large cases, while the one using PETSc 3.6 is
>>>>> robust.
>>>>> After a few tests, I found that the scaling is mostly sensitive to the
>>>>> use of the AMG method for the coarse grid (line 1780 in
>>>>> main_ex42_petsc36.cc). In particular, the performance strongly
>>>>> deteriorates when commenting lines 1777 to 1790 (in
>>>>> Do you have any idea of what changed between version 3.6 and version
>>>>> 3.10 that may imply such degradation?
>>>> I believe the default values for PCGAMG changed between versions. It
>>>> sounds like the coarsening rate
>>>> is not great enough, so that these grids are too large. This can be set
>>>> using:
>>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGAMGSetThreshold.html
>>>> There is some explanation of this effect on that page. Let us know if
>>>> setting this does not correct the situation.
>>>>   Thanks,
>>>>      Matt
>>>>> Let me know if you need further information.
>>>>> Best,
>>>>> Myriam Peyrounette
>>>>> Myriam Peyrounette
>>>>> CNRS/IDRIS - HLST
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/%7Eknepley/>
>>>> Myriam Peyrounette
>>>> CNRS/IDRIS - HLST
>>> experiments lead.
>>> -- Norbert Wiener
>>> Myriam Peyrounette
>>> CNRS/IDRIS - HLST
>> Myriam Peyrounette
>> CNRS/IDRIS - HLST
> Myriam Peyrounette
> CNRS/IDRIS - HLST
> Myriam Peyrounette
> CNRS/IDRIS - HLST
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190320/017d1091/attachment.html>
