[petsc-users] MPI Communication times
Zhang, Junchao
jczhang at mcs.anl.gov
Wed Mar 20 17:24:53 CDT 2019
Forgot to mention long VecScatter time might also due to local memory copies. If the communication pattern has large local to local (self to self) scatter, which often happens thanks to locality, then the memory copy time is counted in VecScatter. You can analyze your code's communication pattern to see if it is the case.
--Junchao Zhang
On Wed, Mar 20, 2019 at 4:44 PM Zhang, Junchao via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
On Wed, Mar 20, 2019 at 4:18 PM Manuel Valera <mvalera-w at sdsu.edu<mailto:mvalera-w at sdsu.edu>> wrote:
Thanks for your answer, so for example i have a log for 200 cores across 10 nodes that reads:
Event Count Time (sec) Flop --- Global --- --- Stage --- Total
Max Ratio Max Ratio Max Ratio Mess Avg len Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
VecScatterBegin 3014 1.0 4.5550e+01 2.6 0.00e+00 0.0 4.2e+06 1.1e+06 2.8e+01 4 0 63 56 0 4 0 63 56 0 0
VecScatterEnd 2976 1.0 1.2143e+02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 14 0 0 0 0 14 0 0 0 0 0
While for 20 nodes at one node i have:
What does that mean?
VecScatterBegin 2596 1.0 2.9142e+01 2.1 0.00e+00 0.0 1.2e+05 4.0e+06 3.0e+01 2 0 81 61 0 2 0 81 61 0 0
VecScatterEnd 2558 1.0 8.0344e+01 7.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 3 0 0 0 0 3 0 0 0 0 0
Where do i see the max/min ratio in here? and why End step is all 0.0e00 in both but still grows from 3% to 14% of total time? It seems i would need to run again with the -log_sync option, is this correct?
e.g., 2.1, 7.9. MPI send/recv are in VecScatterBegin(). VecScatterEnd() only does MPI_Wait. That is why it has zero messages. Yes, run with -log_sync and see what happens.
Different question, can't i estimate the total communication time if i had a typical communication time per MPI message times the number of MPI messages reported in the log? or it doesn't work like that?
Probably not work because you have multiple processes doing send/recv at the same time. They might saturate the bandwidth. Petsc also does computation/communication overlapping.
Thanks.
On Wed, Mar 20, 2019 at 2:02 PM Zhang, Junchao <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>> wrote:
See the "Mess AvgLen Reduct" number in each log stage. Mess is the total number of messages sent in an event over all processes. AvgLen is average message len. Reduct is the number of global reduction.
Each event like VecScatterBegin/End has a maximal execution time over all processes, and a max/min ratio. %T is sum(execution time of the event on each process)/sum(execution time of the stage on each process). %T indicates how expensive the event is. It is a number you should pay attention to.
If your code is imbalanced (i.e., with a big max/min ratio), then the performance number is skewed and becomes misleading because some processes are just waiting for others. Then, besides -log_view, you can add -log_sync, which adds an extra MPI_Barrier for each event to let them start at the same time. With that, it is easier to interpret the number.
src/vec/vscat/examples/ex4.c is a tiny example for VecScatter logging.
--Junchao Zhang
On Wed, Mar 20, 2019 at 2:58 PM Manuel Valera via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hello,
I am working on timing my model, which we made MPI scalable using petsc DMDAs, i want to know more about the output log and how to calculate a total communication times for my runs, so far i see we have "MPI Messages" and "MPI Messages Lengths" in the log, along VecScatterEnd and VecScatterBegin reports.
My question is, how do i interpret these number to get a rough estimate on how much overhead we have just from MPI communications times in my model runs?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190320/7315a363/attachment.html>
