[petsc-users] MPI Communication times
Manuel Valera mvalera-w at sdsu.edu
Wed Mar 20 17:07:45 CDT 2019
Sorry i meant 20 cores at one node. Ok i will retry with -log_sync and come
back. Thanks for your help.
On Wed, Mar 20, 2019 at 2:43 PM Zhang, Junchao <jczhang at mcs.anl.gov> wrote:
> On Wed, Mar 20, 2019 at 4:18 PM Manuel Valera <mvalera-w at sdsu.edu> wrote:
>> Thanks for your answer, so for example i have a log for 200 cores across
>> 10 nodes that reads:
>> Event                           Count      Time (sec)     Flop
>>                  --- Global ---  --- Stage ---   Total
>>                                 Max Ratio  Max     Ratio   Max  Ratio
>> Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>> VecScatterBegin     3014 1.0 4.5550e+01 2.6 0.00e+00 0.0 *4.2e+06
>> 1.1e+06 2.8e+01  4*  0 63 56  0   4  0 63 56  0     0
>> VecScatterEnd       2976 1.0 1.2143e+02 1.7 0.00e+00 0.0 *0.0e+00
>> 0.0e+00 0.0e+00 14*  0  0  0  0  14  0  0  0  0     0
>> While for 20 nodes at one node i have:
>  What does that mean?
>> VecScatterBegin     2596 1.0 2.9142e+01 2.1 0.00e+00 0.0 *1.2e+05
>> 4.0e+06 3.0e+01  2*  0 81 61  0   2  0 81 61  0     0
>> VecScatterEnd       2558 1.0 8.0344e+01 7.9 0.00e+00 0.0  *0.0e+00
>> 0.0e+00 0.0e+00  3*  0  0  0  0   3  0  0  0  0     0
>> Where do i see the max/min ratio in here? and why End step is all 0.0e00
>> in both but still grows from 3% to 14% of total time? It seems i would need
>> to run again with the -log_sync option, is this correct?
>> e.g., 2.1, 7.9. MPI send/recv are in VecScatterBegin(). VecScatterEnd()
> only does MPI_Wait. That is why it has zero messages. Yes, run with
> -log_sync and see what happens.
>> Different question, can't i estimate the total communication time if i
>> had a typical communication time per MPI message times the number of MPI
>> messages reported in the log? or it doesn't work like that?
>> Probably not work because you have multiple processes doing send/recv at
> the same time. They might saturate the bandwidth. Petsc also does
> computation/communication overlapping.
>> Thanks.
>> On Wed, Mar 20, 2019 at 2:02 PM Zhang, Junchao <jczhang at mcs.anl.gov>
>> wrote:
>>> See the "Mess   AvgLen  Reduct" number in each log stage.  Mess is the
>>> total number of messages sent in an event over all processes.  AvgLen is
>>> average message len. Reduct is the number of global reduction.
>>> Each event like VecScatterBegin/End has a maximal execution time over
>>> all processes, and a max/min ratio.  %T is sum(execution time of the event
>>> on each process)/sum(execution time of the stage on each process). %T
>>> indicates how expensive the event is. It is a number you should pay
>>> attention to.
>>> If your code is imbalanced (i.e., with a big max/min ratio), then the
>>> performance number is skewed and becomes misleading because some processes
>>> are just waiting for others. Then, besides -log_view, you can add
>>> -log_sync, which adds an extra MPI_Barrier for each event to let them start
>>> at the same time. With that, it is easier to interpret the number.
>>> src/vec/vscat/examples/ex4.c is a tiny example for VecScatter logging.
>>> --Junchao Zhang
>>> On Wed, Mar 20, 2019 at 2:58 PM Manuel Valera via petsc-users <
>>> petsc-users at mcs.anl.gov> wrote:
>>>> Hello,
>>>> I am working on timing my model, which we made MPI scalable using petsc
>>>> DMDAs, i want to know more about the output log and how to calculate a
>>>> total communication times for my runs, so far i see we have "MPI Messages"
>>>> and "MPI Messages Lengths" in the log, along VecScatterEnd and
>>>> VecScatterBegin reports.
>>>> My question is, how do i interpret these number to get a rough estimate
>>>> on how much overhead we have just from MPI communications times in my model
>>>> runs?
>>>> Thanks,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190320/1b75a6ea/attachment.html>
