[petsc-users] Problems about GMRES restart and Scaling
Wed Mar 20 07:00:06 CDT 2019
On Wed, Mar 20, 2019 at 6:53 AM Yingjie Wu via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear PETSc developers:
> Hi,
> Recently, I used PETSc to solve a non-linear PDEs for thermodynamic
> problems. In the process of solving, I found the following two phenomena,
> hoping to get some help and suggestions.
> 1. Because my problem involves a lot of physical parameters, it needs to
> call a series of functions, and can not analytically construct Jacobian
> matrix, so I use - snes_mf_operator to solve it, and give an approximate
> Jacobian matrix as a preconditioner. Because of the large dimension of the
> problem and the magnitude difference of the physical variables involved, it
> is found that the linear step residuals will increase at each restart
> (default 30th linear step) . This problem can be solved by setting a large
> number of restart steps. I would like to ask the reasons for this
> phenomenon? What knowledge or articles should I learn if I want to find out
> this problem?
Make sure you non-dimensionalize the problem first, so that any scale
differences are real and not the result of units.
> 2. In my problem model, there are many physical fields (variables are
> realized by finite difference method), and the magnitude of variables
> varies greatly. Is there any Scaling interface or function in Petsc?
That is what Jacobi does.
    Matt
> Thanks,
> Yingjie
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190320/658b4e28/attachment.html>
