[petsc-users] Confusing Schur preconditioner behaviour
Justin Chang jychang48 at gmail.com
Mon Mar 18 16:01:17 CDT 2019
Colin,
1) What equations are you solving?
2) In your second case, you set the outer ksp to preonly, thus we are
unable to see the ksp_monitor for the (firedrake_0_) solver. Set it to
gmres and see if you have a similar output to your first case:
0 KSP preconditioned resid norm 4.985448866758e+00 true resid norm
1.086016610848e-03 ||r(i)||/||b|| 1.000000000000e+00
1 KSP preconditioned resid norm 1.245615753306e-13 true resid norm
2.082000915439e-14 ||r(i)||/||b|| 1.917098591903e-11
Because according to the first ksp_view output, after one lu sweep for the
(firedrake_0_fieldsplit_1_) solver. That is, going from:
0 KSP preconditioned resid norm 8.819238435108e-02 true resid norm
1.797571993221e-01 ||r(i)||/||b|| 1.000000000000e+00
to
1 KSP preconditioned resid norm 1.025167319984e-02 true resid norm
3.340583874349e-02 ||r(i)||/||b|| 1.858386694356e-01
appeared to give you an exact schur complement.
Justin
On Mon, Mar 18, 2019 at 2:18 PM Cotter, Colin J via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Sorry, just to clarify, in the second case I see several *inner*
> iterations, even though I'm using LU on a supposedly exact Schur complement
> as the preconditioner for the Schur system.
> *From:* petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of
> Cotter, Colin J via petsc-users <petsc-users at mcs.anl.gov>
> *Sent:* 18 March 2019 20:14:48
> *To:* petsc-users at mcs.anl.gov
> *Subject:* [petsc-users] Confusing Schur preconditioner behaviour
> Dear petsc-users,
>   I'm solving a 2x2 block system, for which I can construct the Schur
> complement analytically (through compatible FEM stuff),
> which I can pass as the preconditioning matrix.
> When using gmres on the outer iteration, and preonly+lu on the inner
> iterations with a Schur complement preconditioner,
> I see convergence in 1 iteration as expected. However, when I set gmres+lu
> on the inner iteration for S, I see several iterations.
> This seems strange to me, as the first result seems to confirm that I have
> an exact Schur complement, but the second result
> implies not.
> What could be going on here?
> I've appended output to the bottom of this message, first the preonly+lu
> and then for gmres+lu.
> all the best
> --Colin
>    Linear firedrake_0_fieldsplit_1_ solve converged due to CONVERGED_ITS
> iterations 1
>     Residual norms for firedrake_0_ solve.
> iterations 1
> KSP Object: (firedrake_0_) 1 MPI processes
>   type: gmres
>     restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     happy breakdown tolerance 1e-30
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-07, absolute=1e-50, divergence=10000.
>   left preconditioning
>   using PRECONDITIONED norm type for convergence test
> PC Object: (firedrake_0_) 1 MPI processes
>   type: fieldsplit
>     FieldSplit with Schur preconditioner, factorization FULL
>     Preconditioner for the Schur complement formed from A11
>     Split info:
>     Split number 0 Defined by IS
>     Split number 1 Defined by IS
>     KSP solver for A00 block
>       KSP Object: (firedrake_0_fieldsplit_0_) 1 MPI processes
>         type: preonly
>         tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>         using NONE norm type for convergence test
>       PC Object: (firedrake_0_fieldsplit_0_) 1 MPI processes
>         type: lu
>           out-of-place factorization
>           tolerance for zero pivot 2.22045e-14
>           matrix ordering: nd
>           factor fill ratio given 5., needed 1.
>             Factored matrix follows:
>               Mat Object: 1 MPI processes
>                 type: seqaij
>                 rows=6144, cols=6144
>                 package used to perform factorization: petsc
>                 total: nonzeros=18432, allocated nonzeros=18432
>                 total number of mallocs used during MatSetValues calls =0
>                   using I-node routines: found 2048 nodes, limit used is 5
>         linear system matrix = precond matrix:
>         Mat Object: (firedrake_0_fieldsplit_0_) 1 MPI processes
>           type: seqaij
>     KSP solver for S = A11 - A10 inv(A00) A01
>       KSP Object: (firedrake_0_fieldsplit_1_) 1 MPI processes
>         type: preonly
>       PC Object: (firedrake_0_fieldsplit_1_) 1 MPI processes
>         type: lu
>           matrix ordering: nd
>           factor fill ratio given 5., needed 5.09173
>                 type: seqaij
>                 rows=15360, cols=15360
>                 total: nonzeros=1360836, allocated nonzeros=1360836
>                   using I-node routines: found 5120 nodes, limit used is 5
>         linear system matrix followed by preconditioner matrix:
>         Mat Object: (firedrake_0_fieldsplit_1_) 1 MPI processes
>           type: schurcomplement
>             Schur complement A11 - A10 inv(A00) A01
>             A11
>                 type: seqaij
>                 total: nonzeros=267264, allocated nonzeros=267264
>             A10
>                 type: seqaij
>                 rows=15360, cols=6144
>                 total: nonzeros=73728, allocated nonzeros=73728
>             KSP of A00
>                 type: preonly
> divergence=10000.
>                 type: lu
>                   matrix ordering: nd
>                         type: seqaij
> calls =0
> used is 5
>                   type: seqaij
> 5
>             A01
>                 type: seqaij
>                 rows=6144, cols=15360
>           type: seqaij
>   Mat Object: (firedrake_0_) 1 MPI processes
>     type: nest
>     rows=21504, cols=21504
>       Matrix object:
>         type=nest, rows=2, cols=2
>         MatNest structure:
>         (0,0) : type=seqaij, rows=15360, cols=15360
>         (0,1) : type=seqaij, rows=15360, cols=6144
>         (1,0) : type=seqaij, rows=6144, cols=15360
>         (1,1) : type=seqaij, rows=6144, cols=6144
>     type: nest
>       Matrix object:
>         MatNest structure:
>         (0,0) : prefix="firedrake_0_fieldsplit_1_", type=seqaij,
>         (1,1) : prefix="firedrake_0_fieldsplit_0_", type=seqaij,
>       Residual norms for firedrake_0_fieldsplit_1_ solve.
>       2 KSP preconditioned resid norm 1.235104644359e-03 true resid norm
> 8.148396804822e-03 ||r(i)||/||b|| 4.533001646417e-02
>       3 KSP preconditioned resid norm 1.624748553125e-04 true resid norm
> 1.612221957927e-03 ||r(i)||/||b|| 8.968886720573e-03
>       4 KSP preconditioned resid norm 2.233373761266e-05 true resid norm
> 3.292437172839e-04 ||r(i)||/||b|| 1.831602397710e-03
>       5 KSP preconditioned resid norm 1.895393184017e-06 true resid norm
> 4.091207337005e-05 ||r(i)||/||b|| 2.275962994770e-04
>       6 KSP preconditioned resid norm 1.699212495729e-07 true resid norm
> 3.851173419652e-06 ||r(i)||/||b|| 2.142430697728e-05
>     Linear firedrake_0_fieldsplit_1_ solve converged due to CONVERGED_RTOL
> iterations 6
>   type: preonly
>   type: fieldsplit
>     Split info:
>         type: preonly
>         type: lu
>           matrix ordering: nd
>                 type: seqaij
>           type: seqaij
>         type: gmres
>         type: lu
>           matrix ordering: nd
>                 type: seqaij
>             A11
>                 type: seqaij
>             A10
>                 type: seqaij
>             KSP of A00
>                 type: preonly
> divergence=10000.
>                 type: lu
>                   matrix ordering: nd
>                         type: seqaij
> calls =0
> used is 5
>                   type: seqaij
> 5
>             A01
>                 type: seqaij
>           type: seqaij
>     type: nest
>       Matrix object:
>         MatNest structure:
>     type: nest
>       Matrix object:
>         MatNest structure:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190318/a30a7ed5/attachment-0001.html>
