[petsc-users] PetscScatterCreate type mismatch after update.
Zhang, Junchao
jczhang at mcs.anl.gov
Tue Mar 12 20:42:52 CDT 2019
Maybe you should delete your PETSC_ARCH directory and recompile it? I tested my branch. It should not that easily fail :)
--Junchao Zhang
On Tue, Mar 12, 2019 at 8:20 PM Manuel Valera <mvalera-w at sdsu.edu<mailto:mvalera-w at sdsu.edu>> wrote:
Hi Mr Zhang, thanks for your reply,
I just checked your branch out, reconfigured and recompiled and i am still getting the same error from my last email (null argument, when expected a valid pointer), do you have any idea why this can be happening?
Thanks so much,
Manuel
On Tue, Mar 12, 2019 at 6:09 PM Zhang, Junchao <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>> wrote:
Manuel,
I was working on a branch to revert the VecScatterCreate to VecScatterCreateWithData change. The change broke PETSc API and I think we do not need it. I had planed to do a pull request after my another PR is merged.
But since it already affects you, you can try this branch now, which is jczhang/fix-vecscattercreate-api
Thanks.
--Junchao Zhang
On Tue, Mar 12, 2019 at 5:58 PM Jed Brown via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Did you just update to 'master'? See VecScatter changes:
https://www.mcs.anl.gov/petsc/documentation/changes/dev.html
Manuel Valera via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> writes:
> Hello,
> I just updated petsc from the repo to the latest master branch version, and
> a compilation problem popped up, it seems like the variable types are not
> being acknowledged properly, what i have in a minimum working example
> fashion is:
> #include <petsc/finclude/petscvec.h>
>> #include <petsc/finclude/petscdmda.h>
>> #include <petsc/finclude/petscdm.h>
>> #include <petsc/finclude/petscis.h>
>> #include <petsc/finclude/petscksp.h>
>> USE petscvec
>> USE petscdmda
>> USE petscdm
>> USE petscis
>> USE petscksp
>> IS :: ScalarIS
>> IS :: DummyIS
>> VecScatter :: LargerToSmaller,to0,from0
>> VecScatter :: SmallerToLarger
>> PetscInt, ALLOCATABLE :: pScalarDA(:), pDummyDA(:)
>> PetscScalar :: rtol
>> Vec :: Vec1
>> Vec :: Vec2
>> ! Create index sets
>> allocate( pScalarDA(0:(gridx-1)*(gridy-1)*(gridz-1)-1) ,
>> pDummyDA(0:(gridx-1)*(gridy-1)*(gridz-1)-1) )
>> iter=0
>> do k=0,gridz-2
>> kplane = k*gridx*gridy
>> do j=0,gridy-2
>> do i=0,gridx-2
>> pScalarDA(iter) = kplane + j*(gridx) + i
>> iter = iter+1
>> enddo
>> enddo
>> enddo
>> pDummyDA = (/ (ind, ind=0,((gridx-1)*(gridy-1)*(gridz-1))-1) /)
>> call
>> ISCreateGeneral(PETSC_COMM_WORLD,(gridx-1)*(gridy-1)*(gridz-1), &
>> pScalarDA,PETSC_COPY_VALUES,ScalarIS,ierr)
>> call
>> pDummyDA,PETSC_COPY_VALUES,DummyIS,ierr)
>> deallocate(pScalarDA,pDummyDA, STAT=ierr)
>> ! Create VecScatter contexts: LargerToSmaller & SmallerToLarger
>> call DMDACreateNaturalVector(daScalars,Vec1,ierr)
>> call DMDACreateNaturalVector(daDummy,Vec2,ierr)
>> call
>> VecScatterCreate(Vec1,ScalarIS,Vec2,DummyIS,LargerToSmaller,ierr)
>> call
>> VecScatterCreate(Vec2,DummyIS,Vec1,ScalarIS,SmallerToLarger,ierr)
>> call VecDestroy(Vec1,ierr)
>> call VecDestroy(Vec2,ierr)
> And the error i get is the part i cannot really understand:
> matrixobjs.f90:99.34:
>> call
>> 1
>> Error: Type mismatch in argument 'a' at (1); passed TYPE(tvec) to
>> INTEGER(4)
>> matrixobjs.f90:100.34:
>> call
>> 1
>> INTEGER(4)
>> make[1]: *** [matrixobjs.o] Error 1
>> make[1]: Leaving directory `/usr/scratch/valera/ParGCCOM-Master/Src'
>> make: *** [gcmSeamount] Error 2
> What i find hard to understand is why/where my code is finding an integer
> type? as you can see from the MWE header the variables types look correct,
> Any help is appreaciated,
> Thanks,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190313/f602f7fc/attachment-0001.html>
