[petsc-users] PetscScatterCreate type mismatch after update.
Manuel Valera
mvalera-w at sdsu.edu
Tue Mar 12 20:19:28 CDT 2019
Hi Mr Zhang, thanks for your reply,
I just checked your branch out, reconfigured and recompiled and i am still
getting the same error from my last email (null argument, when expected a
valid pointer), do you have any idea why this can be happening?
Thanks so much,
Manuel
On Tue, Mar 12, 2019 at 6:09 PM Zhang, Junchao <jczhang at mcs.anl.gov> wrote:
> Manuel,
> I was working on a branch to revert the VecScatterCreate to
> VecScatterCreateWithData change. The change broke PETSc API and I think we
> do not need it. I had planed to do a pull request after my another PR is
> merged.
> But since it already affects you, you can try this branch now, which is
> jczhang/fix-vecscattercreate-api
> Thanks.
> --Junchao Zhang
> On Tue, Mar 12, 2019 at 5:58 PM Jed Brown via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Did you just update to 'master'? See VecScatter changes:
>> https://www.mcs.anl.gov/petsc/documentation/changes/dev.html
>> Manuel Valera via petsc-users <petsc-users at mcs.anl.gov> writes:
>> > Hello,
>> > I just updated petsc from the repo to the latest master branch version,
>> and
>> > a compilation problem popped up, it seems like the variable types are
>> not
>> > being acknowledged properly, what i have in a minimum working example
>> > fashion is:
>> > #include <petsc/finclude/petscvec.h>
>> >> #include <petsc/finclude/petscdmda.h>
>> >> #include <petsc/finclude/petscdm.h>
>> >> #include <petsc/finclude/petscis.h>
>> >> #include <petsc/finclude/petscksp.h>
>> >> USE petscvec
>> >> USE petscdmda
>> >> USE petscdm
>> >> USE petscis
>> >> USE petscksp
>> >> IS :: ScalarIS
>> >> IS :: DummyIS
>> >> VecScatter :: LargerToSmaller,to0,from0
>> >> VecScatter :: SmallerToLarger
>> >> PetscInt, ALLOCATABLE :: pScalarDA(:), pDummyDA(:)
>> >> PetscScalar :: rtol
>> >> Vec :: Vec1
>> >> Vec :: Vec2
>> >> ! Create index sets
>> >> allocate( pScalarDA(0:(gridx-1)*(gridy-1)*(gridz-1)-1) ,
>> >> pDummyDA(0:(gridx-1)*(gridy-1)*(gridz-1)-1) )
>> >> iter=0
>> >> do k=0,gridz-2
>> >> kplane = k*gridx*gridy
>> >> do j=0,gridy-2
>> >> do i=0,gridx-2
>> >> pScalarDA(iter) = kplane + j*(gridx) + i
>> >> iter = iter+1
>> >> enddo
>> >> enddo
>> >> enddo
>> >> pDummyDA = (/ (ind,
>> ind=0,((gridx-1)*(gridy-1)*(gridz-1))-1) /)
>> >> call
>> >> ISCreateGeneral(PETSC_COMM_WORLD,(gridx-1)*(gridy-1)*(gridz-1), &
>> >> pScalarDA,PETSC_COPY_VALUES,ScalarIS,ierr)
>> >> call
>> >> pDummyDA,PETSC_COPY_VALUES,DummyIS,ierr)
>> >> deallocate(pScalarDA,pDummyDA, STAT=ierr)
>> >> ! Create VecScatter contexts: LargerToSmaller &
>> SmallerToLarger
>> >> call DMDACreateNaturalVector(daScalars,Vec1,ierr)
>> >> call DMDACreateNaturalVector(daDummy,Vec2,ierr)
>> >> call
>> >> VecScatterCreate(Vec1,ScalarIS,Vec2,DummyIS,LargerToSmaller,ierr)
>> >> call
>> >> VecScatterCreate(Vec2,DummyIS,Vec1,ScalarIS,SmallerToLarger,ierr)
>> >> call VecDestroy(Vec1,ierr)
>> >> call VecDestroy(Vec2,ierr)
>> > And the error i get is the part i cannot really understand:
>> > matrixobjs.f90:99.34:
>> >> call
>> >> 1
>> >> Error: Type mismatch in argument 'a' at (1); passed TYPE(tvec) to
>> >> INTEGER(4)
>> >> matrixobjs.f90:100.34:
>> >> call
>> >> 1
>> >> INTEGER(4)
>> >> make[1]: *** [matrixobjs.o] Error 1
>> >> make[1]: Leaving directory `/usr/scratch/valera/ParGCCOM-Master/Src'
>> >> make: *** [gcmSeamount] Error 2
>> > What i find hard to understand is why/where my code is finding an
>> integer
>> > type? as you can see from the MWE header the variables types look
>> correct,
>> > Any help is appreaciated,
>> > Thanks,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190312/6d65298a/attachment.html>
