[petsc-users] Problem in MatSetValues
Eda Oktay eda.oktay at metu.edu.tr
Mon Mar 11 08:07:04 CDT 2019
Dear Matt,
I printed in wrong state, ncols gives right solution.
But I still can't understand the first problem.
Eda
Eda Oktay <eda.oktay at metu.edu.tr>, 11 Mar 2019 Pzt, 16:05 tarihinde şunu
yazdı:
> Dear Matt,
> Thank you for answering. First of all, sizeof(vals) returns to number of
> entries, I checked. Secondly, I found a problem:
> ncols gives me 6.95328e-310. However, I checked the matrix L, it was
> computed properly.
> Why can ncols give such a value?
> Thanks,
> Eda
> Matthew Knepley <knepley at gmail.com>, 11 Mar 2019 Pzt, 15:56 tarihinde
> şunu yazdı:
>> On Mon, Mar 11, 2019 at 8:27 AM Eda Oktay via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> Hello,
>>> I have a following part of a code which tries to change the nonzero
>>> values of matrix L with -1. However in MatSetValues line, something happens
>>> and some of the values in matrix turns into 1.99665e-314 instead of -1.
>>> Type of arr is defined as PetscScalar and arr is produced correctly. What
>>> can be the problem, is there a mistake about types?
>>> Thanks,
>>> Eda
>>> for(rw = mm; rw<nn; ++rw){
>>>             ierr = MatGetRow(L,rw,&ncols,&cols,&vals);CHKERRQ(ierr);
>>>             s = sizeof(vals);
>> This is wrong. sizeof(vals) gives bytes, not entries. Why don't you just
>> use ncols here?
>>   Matt
>>>             ierr = PetscMalloc1(s,&arr);CHKERRQ(ierr);
>>>             for(j=0;j<s;++j){
>>>                 arr[j]=-1.0;
>>>             ierr =
>>> MatSetValues(NSymmA,1,&rw,ncols,cols,arr,INSERT_VALUES);CHKERRQ(ierr);
>>>             ierr = MatRestoreRow(L,rw,&ncols,&cols,&vals);CHKERRQ(ierr);
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190311/0e4e4b26/attachment-0001.html>
