[petsc-users] Bad memory scaling with PETSc 3.10
Myriam Peyrounette
myriam.peyrounette at idris.fr
Mon Mar 11 05:32:26 CDT 2019
good point, I changed the 3.10 version so that it is configured with
--with-debugging=0. You'll find attached the output of the new LogView.
The execution time is reduced (although still not as good as 3.6) but I
can't see any improvement with regard to memory.
You'll also find attached the grep GAMG on -info outputs for both
versions. There are slight differences in grid dimensions or nnz values,
but is it significant?
Myriam
Le 03/08/19 à 23:23, Mark Adams a écrit :
> Just seeing this now. It is hard to imagine how bad GAMG could be on a
> coarse grid, but you can run with -info and grep on GAMG and send
> that. You will see listing of levels, number of equations and number
> of non-zeros (nnz). You can send that and I can get some sense of GAMG
> is going nuts.
> Mark
> On Fri, Mar 8, 2019 at 11:56 AM Jed Brown via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> It may not address the memory issue, but can you build 3.10 with the
> same options you used for 3.6? It is currently a debugging build:
> # WARNING!!!
> # This code was compiled with a debugging option.
> # To get timing results run ./configure
> # using --with-debugging=no, the performance will
> # be generally two or three times faster.
Myriam Peyrounette
CNRS/IDRIS - HLST
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190311/113d0dcf/attachment.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190311/113d0dcf/attachment.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190311/113d0dcf/attachment-0001.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190311/113d0dcf/attachment-0002.bin>
Type: application/pkcs7-signature
Desc: Signature cryptographique S/MIME
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190311/113d0dcf/attachment.p7s>
