[petsc-users] EPSGetEigenpair Problem
Eda Oktay
eda.oktay at metu.edu.tr
Sat Mar 9 09:01:20 CST 2019
Dear Matt,
Thank you for your example. I didn't compile your program since I fixed my
problem, now I get a value. However, now I get a different error:
[0]PETSC ERROR: Argument out of range
[0]PETSC ERROR: Argument 2 out of range
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.10.3, Dec, 18, 2018
[0]PETSC ERROR: ./ENYENI_FINAL on a arch-linux2-c-debug named
localhost.localdomain by edaoktay Sat Mar 9 17:55:23 2019
[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
--with-fc=gfortran --with-cxx-dialect=C++11 --download-openblas
--download-metis --download-parmetis --download-superlu_dist
--download-slepc --download-mpich
[0]PETSC ERROR: #1 EPSGetEigenpair() line 398 in
/home/edaoktay/petsc-3.10.3/arch-linux2-c-debug/externalpackages/git.slepc/src/eps/interface/epssolve.c
I didn't understand why the arguments are out of range. I used this
function as:
ierr = EPSGetEigenpair(eps,0,&kr,NULL,vr,NULL);
By the way, even though I get this error, I think EPSGetEigenpair computes
something since I get 4.07265e-314 (which is obviously not true) as the
second smallest eigenvalue.
Eda
Matthew Knepley <knepley at gmail.com>, 8 Mar 2019 Cum, 16:41 tarihinde şunu
yazdı:
> On Fri, Mar 8, 2019 at 8:38 AM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
>> Dear Matt,
>> Thank you for your answer but I get an error even before compiling ex6.
>> The error is:
>> error: too many arguments to function ‘DMSetField’
>> ierr = DMSetField(dm, 0, NULL, (PetscObject) fe);CHKERRQ(ierr);
> You need PETSc master and slepc-dev.
> Thanks,
> Matt
>> Eda
>> Matthew Knepley <knepley at gmail.com>, 7 Mar 2019 Per, 15:07 tarihinde
>> şunu yazdı:
>>> On Thu, Mar 7, 2019 at 6:45 AM Eda Oktay via petsc-users <
>>> petsc-users at mcs.anl.gov> wrote:
>>>> Hello,
>>>> I have a code finding Laplacian of a matrix and then I need to find
>>>> this Laplacian's second smallest eigenpair. I used EPSGetEigenpair code but
>>>> I get the values like "0." or "4." (I could not get decimals) when I used
>>>> PetscPrintf(PETSC_COMM_WORLD," The second smallest eigenvalue: %g\n",kr)
>>>> line.
>>>> What could be the problem?
>>> Hi Eda,
>>> I have an example that does just this, and I am getting the correct
>>> result. I have not yet checked it in,
>>> but i attach it here. Are you setting the right target?
>>> Thanks,
>>> Matt
>>>> Best regards,
>>>> Eda
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190309/edece112/attachment-0001.html>
