[petsc-users] EPSGetEigenpair Problem
Fri Mar 8 07:40:46 CST 2019
On Fri, Mar 8, 2019 at 8:38 AM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
> Dear Matt,
> Thank you for your answer but I get an error even before compiling ex6.
> The error is:
> error: too many arguments to function ‘DMSetField’
>    ierr = DMSetField(dm, 0, NULL, (PetscObject) fe);CHKERRQ(ierr);
You need PETSc master and slepc-dev.
     Matt
> Eda
> Matthew Knepley <knepley at gmail.com>, 7 Mar 2019 Per, 15:07 tarihinde şunu
> yazdı:
>> On Thu, Mar 7, 2019 at 6:45 AM Eda Oktay via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> Hello,
>>> I have a code finding Laplacian of a matrix and then I need to find this
>>> Laplacian's second smallest eigenpair. I used EPSGetEigenpair code but I
>>> get the values like "0." or "4." (I could not get decimals) when I used
>>> PetscPrintf(PETSC_COMM_WORLD," The second smallest eigenvalue: %g\n",kr)
>>> line.
>>> What could be the problem?
>> Hi Eda,
>> I have an example that does just this, and I am getting the correct
>> result. I have not yet checked it in,
>> but i attach it here. Are you setting the right target?
>>   Thanks,
>>     Matt
>>> Best regards,
>>> Eda
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190308/2dcdd2d6/attachment.html>
