[petsc-users] streams test on hpc
Matthew Knepley
knepley at gmail.com
Tue Mar 5 09:26:05 CST 2019
There is a make target in that benchmarks directory that just builds the
executable. Then you can submit that.
Matt
On Tue, Mar 5, 2019 at 10:21 AM Jed Brown via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Of course, just as you would run any other MPI application.
> GangLu via petsc-users <petsc-users at mcs.anl.gov> writes:
> > Hi all,
> > When installing petsc, there is a stream test that is quite useful.
> > Is it possible to run such test in batch mode, e.g. using pbs script?
> > Thanks.
> > cheers,
> > Gang
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190305/84b25be1/attachment.html>
