[petsc-users] streams test on hpc
Jed Brown jed at jedbrown.org
Tue Mar 5 09:21:47 CST 2019
Of course, just as you would run any other MPI application.
GangLu via petsc-users <petsc-users at mcs.anl.gov> writes:
> Hi all,
> When installing petsc, there is a stream test that is quite useful.
> Is it possible to run such test in batch mode, e.g. using pbs script?
> Thanks.
> cheers,
> Gang
