[petsc-users] AddressSanitizer: attempting free on address which was not malloc()-ed
Matthew Knepley
knepley at gmail.com
Sun Mar 3 13:27:55 CST 2019
On Sun, Mar 3, 2019 at 1:03 PM Yuyun Yang via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> I tried compiling without the sanitizer and running on valgrind. Got a
> bunch of errors “Uninitialised value was created by a stack allocation at
> 0x41B280: ComputeVel_qd::computeVel(double*, double, int&, int)”.
There is no memory management code here, so other parts of the code must be
relevant.
Matt
> HEAP SUMMARY:
> ==74== in use at exit: 96,637 bytes in 91 blocks
> ==74== total heap usage: 47,774 allocs, 47,522 frees, 308,253,653 bytes
> allocated
> LEAK SUMMARY:
> ==74== definitely lost: 0 bytes in 0 blocks
> ==74== indirectly lost: 0 bytes in 0 blocks
> ==74== possibly lost: 0 bytes in 0 blocks
> ==74== still reachable: 96,637 bytes in 91 blocks
> ==74== suppressed: 0 bytes in 0 blocks
> The error is located in the attached code (I’ve extracted only the
> relevant functions), but I couldn’t figure out what is wrong. Is this
> causing the memory corruption/double free error that happens when I execute
> the code?
> Thanks a lot for your help.
> Best regards,
> Yuyun
> *From:* Zhang, Junchao <jczhang at mcs.anl.gov>
> *Sent:* Friday, March 1, 2019 7:36 AM
> *To:* Yuyun Yang <yyang85 at stanford.edu>
> *Subject:* Re: [petsc-users] AddressSanitizer: attempting free on address
> On Fri, Mar 1, 2019 at 1:02 AM Yuyun Yang <yyang85 at stanford.edu> wrote:
> Actually, I also saw a line at the beginning of valgrind saying "shadow
> memory range interleaves with an existing memory mapping. ASan cannot
> proceed properly. ABORTING." I guess the code didn't really run through
> valgrind since it aborted. Should I remove the address sanitizer flag when
> compiling?
> From the message, it seems ASan (not valgrind) aborted. You can try to
> compile without sanitizer and then run with valgrind. If no problem, then
> it is probably a sanitizer issue.
> Get Outlook for iOS <https://aka.ms/o0ukef>
> *From:* Yuyun Yang
> *Sent:* Thursday, February 28, 2019 10:54:57 PM
> *To:* Zhang, Junchao
> Hmm, still getting the same error from address sanitizer even though
> valgrind shows no errors and no leaks are possible.
> Should I ignore that error? My results did run alright.
> Best,
> Yuyun
> *Sent:* Wednesday, February 27, 2019 8:27:17 PM
> *To:* Yuyun Yang
> *Cc:* Matthew Knepley; petsc-users at mcs.anl.gov
> Try the following to see if you can catch the bug easily: 1) Get error
> code for each petsc function and check it with CHKERRQ; 2) Link your code
> with a petsc library with debugging enabled (configured
> with --with-debugging=1); 3) Run your code with valgrind
> --Junchao Zhang
> On Wed, Feb 27, 2019 at 9:04 PM Yuyun Yang <yyang85 at stanford.edu> wrote:
> Hi Junchao,
> This code actually involves a lot of classes and is pretty big. Might be
> an overkill for me to send everything to you. I'd like to know if I see
> this sort of error message, which points to this domain file, is it
> possible that the problem happens in another file (whose operations are
> linked to this one)? If so, I'll debug a little more and maybe send you
> more useful information later.
> Best regards,
> Yuyun
> *Sent:* Wednesday, February 27, 2019 6:24:13 PM
> *To:* Yuyun Yang
> Could you provide a compilable and runnable test so I can try it?
> --Junchao Zhang
> On Wed, Feb 27, 2019 at 7:34 PM Yuyun Yang <yyang85 at stanford.edu> wrote:
> Thanks, I fixed that, but I’m not actually calling the testScatters()
> function in my implementation (in the constructor, the only functions I
> called are setFields and setScatters). So the problem couldn’t have been
> that?
> Best,
> Yuyun
> *Sent:* Wednesday, February 27, 2019 10:50 AM
> *Cc:* Matthew Knepley <knepley at gmail.com>; petsc-users at mcs.anl.gov
> On Wed, Feb 27, 2019 at 10:41 AM Yuyun Yang via petsc-users <
> I called VecDestroy() in the destructor for this object – is that not the
> right way to do it?
> In Domain::testScatters(), you have many VecDuplicate(,&out), You need to
> VecDestroy(&out) before doing new VecDuplicate(,&out);
> How do I implement CHECK ALL RETURN CODES?
> For each PETSc function, do ierr = ...; CHKERRQ(ierr);
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Wednesday, February 27, 2019 7:24 AM
> *Cc:* petsc-users at mcs.anl.gov
> You call VecDuplicate() a bunch, but VecDestroy() only once in the bottom
> function. This is wrong.
> Also, CHECK ALL RETURN CODES. This is the fastest way to find errors.
> Matt
> On Wed, Feb 27, 2019 at 2:06 AM Yuyun Yang via petsc-users <
> Hello team,
> I ran into the address sanitizer error that I hope you could help me with.
> I don’t really know what’s wrong with the way the code frees memory. The
> relevant code file is attached. The line number following domain.cpp
> specifically referenced to the vector _q, which seems a little odd, since
> some other vectors are constructed and freed the same way.
> ==1719==ERROR: AddressSanitizer: attempting free on address which was not
> malloc()-ed: 0x61f0000076c0 in thread T0
> #0 0x7fbf195282ca in __interceptor_free
> (/usr/lib/x86_64-linux-gnu/libasan.so.2+0x982ca)
> #1 0x7fbf1706f895 in PetscFreeAlign
> /home/yyy910805/petsc/src/sys/memory/mal.c:87
> #2 0x7fbf1731a898 in VecDestroy_Seq
> /home/yyy910805/petsc/src/vec/vec/impls/seq/bvec2.c:788
> #3 0x7fbf1735f795 in VecDestroy
> /home/yyy910805/petsc/src/vec/vec/interface/vector.c:408
> #4 0x40dd0a in Domain::~Domain()
> /home/yyy910805/scycle/source/domain.cpp:132
> #5 0x40b479 in main /home/yyy910805/scycle/source/main.cpp:242
> #6 0x7fbf14d2082f in __libc_start_main
> (/lib/x86_64-linux-gnu/libc.so.6+0x2082f)
> #7 0x4075d8 in _start (/home/yyy910805/scycle/source/main+0x4075d8)
> 0x61f0000076c0 is located 1600 bytes inside of 3220-byte region
> [0x61f000007080,0x61f000007d14)
> allocated by thread T0 here:
> #0 0x7fbf19528b32 in __interceptor_memalign
> (/usr/lib/x86_64-linux-gnu/libasan.so.2+0x98b32)
> #1 0x7fbf1706f7e0 in PetscMallocAlign
> /home/yyy910805/petsc/src/sys/memory/mal.c:41
> #2 0x7fbf17073022 in PetscTrMallocDefault
> /home/yyy910805/petsc/src/sys/memory/mtr.c:183
> #3 0x7fbf170710a1 in PetscMallocA
> /home/yyy910805/petsc/src/sys/memory/mal.c:397
> #4 0x7fbf17326fb0 in VecCreate_Seq
> /home/yyy910805/petsc/src/vec/vec/impls/seq/bvec3.c:35
> #5 0x7fbf1736f560 in VecSetType
> /home/yyy910805/petsc/src/vec/vec/interface/vecreg.c:51
> #6 0x7fbf1731afae in VecDuplicate_Seq
> /home/yyy910805/petsc/src/vec/vec/impls/seq/bvec2.c:807
> #7 0x7fbf1735eff7 in VecDuplicate
> /home/yyy910805/petsc/src/vec/vec/interface/vector.c:379
> #8 0x4130de in Domain::setFields()
> /home/yyy910805/scycle/source/domain.cpp:431
> #9 0x40c60a in Domain::Domain(char const*)
> /home/yyy910805/scycle/source/domain.cpp:57
> #10 0x40b433 in main /home/yyy910805/scycle/source/main.cpp:242
> #11 0x7fbf14d2082f in __libc_start_main
> SUMMARY: AddressSanitizer: bad-free ??:0 __interceptor_free
> ==1719==ABORTING
> Thanks very much!
> Yuyun
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190303/c1173466/attachment.html>
