[petsc-users] AddressSanitizer: attempting free on address which was not malloc()-ed
Yuyun Yang yyang85 at stanford.edu
Sun Mar 3 12:03:25 CST 2019
I tried compiling without the sanitizer and running on valgrind. Got a bunch of errors “Uninitialised value was created by a stack allocation at 0x41B280: ComputeVel_qd::computeVel(double*, double, int&, int)”.
HEAP SUMMARY:
==74==     in use at exit: 96,637 bytes in 91 blocks
==74==   total heap usage: 47,774 allocs, 47,522 frees, 308,253,653 bytes allocated
LEAK SUMMARY:
==74==    definitely lost: 0 bytes in 0 blocks
==74==    indirectly lost: 0 bytes in 0 blocks
==74==      possibly lost: 0 bytes in 0 blocks
==74==    still reachable: 96,637 bytes in 91 blocks
==74==         suppressed: 0 bytes in 0 blocks
The error is located in the attached code (I’ve extracted only the relevant functions), but I couldn’t figure out what is wrong. Is this causing the memory corruption/double free error that happens when I execute the code?
Thanks a lot for your help.
Best regards,
Yuyun
Sent: Friday, March 1, 2019 7:36 AM
To: Yuyun Yang <yyang85 at stanford.edu>
Subject: Re: [petsc-users] AddressSanitizer: attempting free on address which was not malloc()-ed
On Fri, Mar 1, 2019 at 1:02 AM Yuyun Yang <yyang85 at stanford.edu<mailto:yyang85 at stanford.edu>> wrote:
Actually, I also saw a line at the beginning of valgrind saying "shadow memory range interleaves with an existing memory mapping. ASan cannot proceed properly. ABORTING." I guess the code didn't really run through valgrind since it aborted. Should I remove the address sanitizer flag when compiling?
From the message, it seems ASan (not valgrind) aborted. You can try to compile without sanitizer and then run with valgrind. If no problem, then it is probably a sanitizer issue.
Get Outlook for iOS<https://aka.ms/o0ukef>
Sent: Thursday, February 28, 2019 10:54:57 PM
To: Zhang, Junchao
Hmm, still getting the same error from address sanitizer even though valgrind shows no errors and no leaks are possible.
Should I ignore that error? My results did run alright.
Best,
Yuyun
From: Zhang, Junchao <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>>
Sent: Wednesday, February 27, 2019 8:27:17 PM
To: Yuyun Yang
Cc: Matthew Knepley; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
Try the following to see if you can catch the bug easily: 1) Get error code for each petsc function and check it with CHKERRQ; 2) Link your code with a petsc library with debugging enabled (configured with --with-debugging=1); 3) Run your code with valgrind
--Junchao Zhang
On Wed, Feb 27, 2019 at 9:04 PM Yuyun Yang <yyang85 at stanford.edu<mailto:yyang85 at stanford.edu>> wrote:
Hi Junchao,
This code actually involves a lot of classes and is pretty big. Might be an overkill for me to send everything to you. I'd like to know if I see this sort of error message, which points to this domain file, is it possible that the problem happens in another file (whose operations are linked to this one)? If so, I'll debug a little more and maybe send you more useful information later.
Best regards,
Yuyun
Sent: Wednesday, February 27, 2019 6:24:13 PM
To: Yuyun Yang
Could you provide a compilable and runnable test so I can try it?
--Junchao Zhang
On Wed, Feb 27, 2019 at 7:34 PM Yuyun Yang <yyang85 at stanford.edu<mailto:yyang85 at stanford.edu>> wrote:
Thanks, I fixed that, but I’m not actually calling the testScatters() function in my implementation (in the constructor, the only functions I called are setFields and setScatters). So the problem couldn’t have been that?
Best,
Yuyun
Sent: Wednesday, February 27, 2019 10:50 AM
To: Yuyun Yang <yyang85 at stanford.edu<mailto:yyang85 at stanford.edu>>
Cc: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
On Wed, Feb 27, 2019 at 10:41 AM Yuyun Yang via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
I called VecDestroy() in the destructor for this object – is that not the right way to do it?
In Domain::testScatters(), you have many VecDuplicate(,&out), You need to VecDestroy(&out) before doing new VecDuplicate(,&out);
How do I implement CHECK ALL RETURN CODES?
For each PETSc function, do ierr = ...;  CHKERRQ(ierr);
From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Sent: Wednesday, February 27, 2019 7:24 AM
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
You call VecDuplicate() a bunch, but VecDestroy() only once in the bottom function. This is wrong.
Also, CHECK ALL RETURN CODES. This is the fastest way to find errors.
   Matt
On Wed, Feb 27, 2019 at 2:06 AM Yuyun Yang via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hello team,
I ran into the address sanitizer error that I hope you could help me with. I don’t really know what’s wrong with the way the code frees memory. The relevant code file is attached. The line number following domain.cpp specifically referenced to the vector _q, which seems a little odd, since some other vectors are constructed and freed the same way.
==1719==ERROR: AddressSanitizer: attempting free on address which was not malloc()-ed: 0x61f0000076c0 in thread T0
    #0 0x7fbf195282ca in __interceptor_free (/usr/lib/x86_64-linux-gnu/libasan.so.2+0x982ca)
    #1 0x7fbf1706f895 in PetscFreeAlign /home/yyy910805/petsc/src/sys/memory/mal.c:87
    #2 0x7fbf1731a898 in VecDestroy_Seq /home/yyy910805/petsc/src/vec/vec/impls/seq/bvec2.c:788
    #3 0x7fbf1735f795 in VecDestroy /home/yyy910805/petsc/src/vec/vec/interface/vector.c:408
    #4 0x40dd0a in Domain::~Domain() /home/yyy910805/scycle/source/domain.cpp:132
    #5 0x40b479 in main /home/yyy910805/scycle/source/main.cpp:242
    #6 0x7fbf14d2082f in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2082f)
    #7 0x4075d8 in _start (/home/yyy910805/scycle/source/main+0x4075d8)
0x61f0000076c0 is located 1600 bytes inside of 3220-byte region [0x61f000007080,0x61f000007d14)
allocated by thread T0 here:
    #0 0x7fbf19528b32 in __interceptor_memalign (/usr/lib/x86_64-linux-gnu/libasan.so.2+0x98b32)
    #1 0x7fbf1706f7e0 in PetscMallocAlign /home/yyy910805/petsc/src/sys/memory/mal.c:41
    #2 0x7fbf17073022 in PetscTrMallocDefault /home/yyy910805/petsc/src/sys/memory/mtr.c:183
    #3 0x7fbf170710a1 in PetscMallocA /home/yyy910805/petsc/src/sys/memory/mal.c:397
    #4 0x7fbf17326fb0 in VecCreate_Seq /home/yyy910805/petsc/src/vec/vec/impls/seq/bvec3.c:35
    #5 0x7fbf1736f560 in VecSetType /home/yyy910805/petsc/src/vec/vec/interface/vecreg.c:51
    #6 0x7fbf1731afae in VecDuplicate_Seq /home/yyy910805/petsc/src/vec/vec/impls/seq/bvec2.c:807
    #7 0x7fbf1735eff7 in VecDuplicate /home/yyy910805/petsc/src/vec/vec/interface/vector.c:379
    #8 0x4130de in Domain::setFields() /home/yyy910805/scycle/source/domain.cpp:431
    #9 0x40c60a in Domain::Domain(char const*) /home/yyy910805/scycle/source/domain.cpp:57
    #10 0x40b433 in main /home/yyy910805/scycle/source/main.cpp:242
    #11 0x7fbf14d2082f in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2082f)
SUMMARY: AddressSanitizer: bad-free ??:0 __interceptor_free
==1719==ABORTING
Thanks very much!
Yuyun
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190303/ee7450e1/attachment-0001.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190303/ee7450e1/attachment-0001.ksh>
