[petsc-users] DMPlexDistributeField
    Zhang, Junchao
    jczhang at mcs.anl.gov
    Wed Jun 26 23:07:27 CDT 2019
On Mon, Jun 24, 2019 at 6:23 PM Adrian Croucher via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
hi
Thanks Matt for the explanation about this.
I have been trying a test which does the following:
1) read in DMPlex from file
2) distribute it, with overlap = 1, using DMPlexDistribute()
3) create FVM cell and face geometry vectors using DMPlexComputeGeometryFVM()
4) re-distribute, again with overlap = 1, using DMPlexDistribute()
5) distribute the cell and face geometry vectors using DMPlexDistributeField()
Steps 4) and 5) should do essentially nothing, because the mesh has already been distributed (but in my actual non-test code, there is additional stuff between steps 3) and 4) where dual porosity cells are added to the DM).
So I expect the cell and face geometry vectors to be essentially unchanged from the redistribution. And the redistribution SF (from the second distribution) should be just an identity mapping on the cell and face points (except for the overlap ghost points).
This is true for the cells, but not the faces. I've attached the example code and mesh. It is a simple mesh with 10 cells in a horizontal line, each cell 50x50x50 m.
If I run on 2 processes, there are 5 cells (points 0 - 4) on each rank, with centroids at 25, 75, 125, 175 and 225 m on rank 0, and 275, 325, 375, 425 and 475 m on rank 1. The internal faces are the points 36, 42, 47 and 52 on rank 0, and 34, 37, 42, 47 and 52 on rank 1. On rank 0 these should have centroids at 50, 100, 150 and 200 m respectively; on rank 1 they should be at 250, 300, 350 and 400 m. This is true before redistribution.
After redistribution, the cells centroids are still correct, and the face data on rank 1 are OK, but the face data on rank 0 are all wrong.
If you look at the redistribution SF the entries for the rank 0 face data are 36 <- (0,40), 42 <- (0,46), 47 <- (0,51), 52 <- (0,56), instead of the expected 36 <- (0,36), 42 <- (0,42), 47 <- (0,47), 52 <- (0,52). The SF for the rank 1 faces is OK.
 Adrian, I am working on SF but know nothing about DMPlexDistributeField. Do you think SF creation or communication is wrong? If yes, I'd like to know the detail.  I have a branch jczhang/sf-more-opts, which adds some optimizations to SF.  It probably won't solve your problem. But since it changes SF a lot, it's better to have a try.
If you change the overlap from 1 to 0, it works as expected. So it looks to me like something isn't quite right with the SF for faces when there is overlap. On rank 0 all the entries seem to be shifted up by 4.
I know you originally recommended using overlap = 0 for the initial distribution and only adding overlap for the redistribution. But then Stefano indicated that it should work with overlap now. And it would simplify my code if I could use overlap for the initial distribution (because if dual porosity cells are not being used, then there is no second redistribution).
Is this a bug or is there something I'm doing wrong?
- Adrian
On 23/06/19 4:39 PM, Matthew Knepley wrote:
On Fri, Jun 21, 2019 at 12:49 AM Adrian Croucher via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
I have been trying to get this FVM geometry data re-distribution to work
using DMPlexDistributeField().
It seems to be working OK for the cell geometry data (cell volumes and
centroids). But it is making a mess of the face geometry data (face
normals and centroids).
Should I even expect DMPlexDistributeField() to work for redistributing
a vector of data defined on mesh faces? Or is there some reason I
haven't thought of, which means that will never work?
Sorry this took a long time. The place I was in France did not have internet.
Here is how this stuff works:
  1) You start with a Section and local vector. The Section describes layout of data in
       the local vector by mapping mesh points to {# dof, offset}. For a small example,
       suppose I had two triangles sharing an edge on a sequential mesh for 2 procs.
       The mesh points would be
         [0, 1]:  Cells
         [2, 5]:  Vertices, where 3,4 are shared
         [6, 10]: Edges, where 8 is shared
       A Section for face normals would then look like
        Process 0
        [0, 5]: {0, 0}   Meaning no variables lie on cells or vertices
        6:       {2, 0}   One vector per face
        7:       {2, 2}
        8:       {2, 4}
        9:       {2, 6}
        10      {2, 8}
        Process 1
        empty
     The vector would just have the face normal values in the canonical order. You can use
     PetscSectionView() to check that yours looks similar.
  2) Now we add a PetscSF describing the redistribution. An SF is a map from a given set of
      integers (leaves) to pairs (int, rank) called roots. Many leaves can point to one root. To begin,
      we provide an SF mapping mesh points to the new distribution
        Process 0
        0 -> {0, 0}
        1 -> {2, 0}
        2 -> {3, 0}
        3 -> {4, 0}
        4 -> {6, 0}
        5 -> {7, 0}
        6 -> {8, 0}
        Process 1
        0 -> {1, 0}
        1 -> {4, 0}
        2 -> {3, 0}
        3 -> {5, 0}
        4 -> {8, 0}
        5 -> {9, 0}
        6 -> {10, 0}
     This tells Petsc how to move the points to the parallel distribution. You can use PetscSFView() to check
     that your point SF is similar. We first use the SF to move the Section data to make a new parallel Section,
       Process 0
       [0, 3]: {0, 0}
       4:       {2, 0}
       5:       {2, 2}
       6:       {2, 4}
       Process 1
       [0, 3]: {0, 0}
       4:       {2, 0}
       5:       {2, 2}
       6:       {2, 4}
     and then we create a new SF that maps dofs, instead of points, using this new Section
     Process 0:
     0 -> {0, 0} First face normal
     1 -> {1, 0}
     2 -> {2, 0} Second face normal
     3 -> {3, 0}
     4 -> {4, 0} Third face normal
     5 -> {5, 0}
     Process 1:
     0 -> {4, 0} First face normal
     1 -> {5, 0}
     2 -> {6, 0} Second face normal
     3 -> {7, 0}
     4 -> {8, 0} Third face normal
     5 -> {9, 0}
    and then this moves the face normal data to the new layout just by broadcasting.
You can View the structures you get back to see what Petsc thought it should do.
Does this make sense?
     Matt
The only example I could find anywhere of DMPlexDistributeField() being
used is in DMPlexDistributeCoordinates() so I've been basing what I'm
doing on that.
(I think I have answered my own questions below by experiment- 1) local
vectors should work (they do in DMPlexDistributeCoordinates); 2)
probably doesn't matter; 3) yes.)
- Adrian
On 6/06/19 1:42 PM, Adrian Croucher wrote:
> hi
> I have some questions about using the DMPlexDistributeField()
> function. I have finite volume mesh geometry data stored in two local
> vectors created using DMPlexComputeGeometryFVM(), and I need to
> redistribute these after calling DMPlexDistribute() to redistribute my
> mesh. (I need the geometry data before redistribution, so I can't just
> wait until after redistribution to create them.)
> So I figured DMPlexDistributeField() looks like the thing to use for
> that, using the SF that comes out of DMPlexDistribute().
> 1) Does DMPlexDistributeField() work on local vectors or do they have
> to be global ones?
> 2) It takes a 'dm' parameter and the documentation says this is "The
> DMPlex object", but is that the original DM (before redistribution) or
> the redistributed one, or does it not matter? It looks like it only
> uses the DM to get the vector type.
> 3) It looks like you need to manually create the newSection and newVec
> output parameters before passing them in to this routine, is that
> correct?
> - Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz<mailto:a.croucher at auckland.ac.nz>
tel: +64 (0)9 923 4611
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
Dr Adrian Croucher
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190627/8e2d0dae/attachment-0001.html>
