[petsc-users] DMPlexDistributeField
Adrian Croucher
a.croucher at auckland.ac.nz
Wed Jun 26 17:43:21 CDT 2019
hi
On 25/06/19 11:22 AM, Adrian Croucher wrote:
> I know you originally recommended using overlap = 0 for the initial
> distribution and only adding overlap for the redistribution. But then
> Stefano indicated that it should work with overlap now. And it would
> simplify my code if I could use overlap for the initial distribution
> (because if dual porosity cells are not being used, then there is no
> second redistribution).
Actually I have also tried this test with overlap = 0 for the initial
distribution, and overlap = 1 for the redistribution, and that doesn't
seem to give correct results for the face geometry either. So that would
suggest that, if there is a problem, it probably doesn't lie in the
stuff that removes overlap cells from the original DM.
I am running PETSc master 3.11.2. I see 3.11.3 is just out, not sure if
there are any changes there which might affect this?
- Adrian
> Is this a bug or is there something I'm doing wrong?
> - Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
