[petsc-users] ParMETIS Load Imbalance
Smith, Barry F.
bsmith at mcs.anl.gov
Thu Jun 20 04:00:27 CDT 2019
> On Jun 20, 2019, at 3:47 AM, Eda Oktay via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hello everyone,
> I am trying to partition a matrix into unequal parts: for example I am trying to partition a 10*10 matrix into 4*4 and 6*6 submatrices. However, ParMETIS is always dividing the matrix into 2 equal parts (5*5).
> The reason why I am trying to do this is that I am using spectral partitioning method.First, I find the eigenvector corresponding to second smallest eigenvalue and then sort the vector according to signs of elements. So, if there is 4 negative values in the vector, the matrix should be divided as 4*4 and 6*6. But I can't do it by using ParMETIS.
I don't understand, if you have your own spectral partitioning code then why would you need or want to use ParMETIS? All ParMETIS does is decide what variables to assign to each process, nothing more.
Would you like to register your spectral partitioning routine and use it with MatPartitioning calls? If so take a look at src/mat/partition/partion.c and the routine MatPartitioningCreate_Current to get an idea of how it is done.
> I tried MatPartitioningSetPartitionWeights but it doesn't work since it only shows when I looked at view imbalance option that partitioning imbalance info: max 6 min 4 but still the matrix was divided into 5*5 and 5*5.
> How can I change the load balance?
> Thanks,
> Eda
