[petsc-users] Extracting parts of DMPLEX mesh
Wed Jun 19 02:36:05 CDT 2019
On Mon, Jun 17, 2019 at 9:49 PM Swarnava Ghosh <swarnava89 at gmail.com> wrote:
> Hi Matthew,
> I am primarily trying to interpolate fields which are defined on vertices.
> For a process, the point at which the interpolation to be carried out can
> be in an element that is owned by another process. My initial plan while
> writing the earlier email was to create local dmplexes in each rank which
> contains all the elements that are required for interpolation. However on
> second thoughts, this is too cumbersome.
Thanks. This is much clearer to me now.
> What might be potentially better approach (ofcourse you will be an expert
> to judge) is to simply extend the ghost region to include the elements of
> the neighbor processes. In this way the points to interpolate at lie in the
> ghost region of the process. Is there a way I could extend the ghost region
> if I know the neighbor ranks?
I see at least two cases:
  1) Only a few points, anywhere in the domain
      If you have a few points that can be anywhere in the domain, I would
use
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/DMInterpolationCreate.html#DMInterpolationCreate
  2) Lots of points, close to boundaries
     If you have lots of points, but off-process points are close to
boundaries, then I would use
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexDistributeOverlap.html
    to get a new, overlapping Plex which you can then use the purely local
point location and interpolation functions.
     Matt
> Sincerely,
> Swarnava
> On Mon, Jun 17, 2019 at 3:13 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Jun 17, 2019 at 6:09 PM Swarnava Ghosh via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> Hi PETSc,
>>> I am trying to extract parts of a distributed dmplex mesh in each MPI
>>> process. For each process, the mesh to extract is the part of the mesh
>>> owned by that process and the parts of the mesh owned by a few neighbor
>>> processes, and the extracted mesh is stored locally to that process. For
>>> each process, I know what the ranks of the neighbor processes are.
>>> Would you please share any ideas on how to go about this?
>> It might be better to start by telling us what you want to do.
>>   Thanks,
>>      Matt
>>> Sincerely,
>>> SG
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190619/3c9d20ce/attachment.html>
