[petsc-users] Extracting parts of DMPLEX mesh
Swarnava Ghosh
swarnava89 at gmail.com
Mon Jun 17 20:48:19 CDT 2019
Hi Matthew,
I am primarily trying to interpolate fields which are defined on vertices.
For a process, the point at which the interpolation to be carried out can
be in an element that is owned by another process. My initial plan while
writing the earlier email was to create local dmplexes in each rank which
contains all the elements that are required for interpolation. However on
second thoughts, this is too cumbersome.
What might be potentially better approach (ofcourse you will be an expert
to judge) is to simply extend the ghost region to include the elements of
the neighbor processes. In this way the points to interpolate at lie in the
ghost region of the process. Is there a way I could extend the ghost region
if I know the neighbor ranks?
Sincerely,
Swarnava
On Mon, Jun 17, 2019 at 3:13 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Jun 17, 2019 at 6:09 PM Swarnava Ghosh via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Hi PETSc,
>> I am trying to extract parts of a distributed dmplex mesh in each MPI
>> process. For each process, the mesh to extract is the part of the mesh
>> owned by that process and the parts of the mesh owned by a few neighbor
>> processes, and the extracted mesh is stored locally to that process. For
>> each process, I know what the ranks of the neighbor processes are.
>> Would you please share any ideas on how to go about this?
> It might be better to start by telling us what you want to do.
> Thanks,
> Matt
>> Sincerely,
>> SG
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190617/54b6d90a/attachment.html>
