[petsc-users] How to do the preallocation and set zeros to rows and columns?
    Matthew Knepley
    knepley at gmail.com
    Fri Jun 14 12:08:33 CDT 2019
On Fri, Jun 14, 2019 at 11:40 AM Dongyu Liu - CITG via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi,
> I am using PETSc to run FEM on domain decomposition. When I assemble the
> matrix, I need to pre-allocate first to get better performance, can you
> recommend how to preallocate in this case?
> Right now we set big values for the number of nonzeros to preallocate
> memory, but when we do so, the program stuck at setZeroRowColumns. The
> error message is like:
> Matrix is missing diagonal entry in row 2.
1) Most preconditioners require a diagonal element, even if it is 0. Thus
it might be good to add diagonal elements, even if they are 0.
2) The best way to preallocate in general is to run your assembly twice.
Once to discover all the nonzero locations, and a second time to
    put in the values. Note that in the first pass, you do not have to
compute the entries, only the indices. We have a matrix class which helps
   with this process:
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatPreallocatorPreallocate.html
     Matt
> Do you have any idea why this happens?
> Note: In the domain decomposition we used, processors share some nodes.
> Best,
> Dongyu
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190614/711dea96/attachment.html>
